Results 1 to 5 of 5
98 Chevy Blower motor
This is a discussion on 98 Chevy Blower motor within the Technical / Maintenance forums, part of the General Discussion category; I have a chevy 3500 pickup and I need to change the blower motor. I thought it would be a ...
    Sep 2008
    Spring, TX
    I have a chevy 3500 pickup and I need to change the blower motor. I thought it would be a good idea to get some suggestions before tearing out the dash. Anyone who has changed one out?
    Feb 2007
    Tenn
    Re: 98 Chevy Blower motor
    Did one on a 99 burb a few months back, but its a 1/2 ton. Piece of cake. Cant see where yours would be any different, but I cant say for sure. Kinda tight when trying to get the new motor into the heater box, have to turn and twist to get it in there. Also, if I remember right, the bolts holding the motor in were 5.5m, which if memory serves me, I didnt have a wrench that size, only a socket. Should be a 30 min job if the 3500 is like a 1/2 ton. Everything is done from underneath by the heater box, I didnt have to tear out the dash as you suggest, but you might have a bigger job than i did.
    Big Daddy 1-8-4-3-6-5-7-2's Avatar
    Jun 2006
    North Pole
    I just did this on my '96 K1500 Suburban.
    Remove the glove box by pulling in on the stops.
    Unhook 2 wires from the motor.
    Remove the plastic cover on the blower motor.
    Remove the bolts that hold the motor in. I think I used a 9/32" socket.
    Twist/pull motor out.
    I had to take the grounding tab from my old motor and put it on the new one.
    '96 Suburban, 17x9 Helo's, 37" Toyo MT's, 14 bolt sf, 5.13 Yukon by Custom Differentials, Black Bear tune!
    D to the MAX gr8shot's Avatar
    Jul 2008
    Grand Island, NE
    It's very easy. You can do everything from under the dash. If I were you and had the blower motor out, I'd clean out the A/C evaporator too. It's also pretty simple to do, and taking out the blower motor is half of the process!! And they supposedly sell evaporator cleaner at parts stores. Just don't be an idiot like me and use engine degreaser!! It STANKS!!
    This thread is sort of an ongoing "how-to" for what your doing.
    http://www.fullsizechevy.com/forums/...ove-obs-c.html
    04 Chevy LB7 Dmax. Some go fast goodies from Husker Diesel
    SOLD!!!! 07.5 Chevy LMM Dmax DPF Deleted, EFI Live from Husker Diesel & more 448hp/834tq
    1992 Chevy 1500 ECSB 4x4 350TBI 320k miles
    '95 Chevy 2500 ECLB swapped in a 95 12v cummins, NV4500, 2wd
    Rest In Peace #3 intimidator4x4's Avatar
    Dec 2007
    Southeastern Indiana
    I've done a few, not too bad of a job
    V INTIMIDATOR has been SOLD V
    98 RCLB Z71 all stock
