Results 1 to 16 of 16
92 Gmc Service Engine Soon
This is a discussion on 92 Gmc Service Engine Soon within the Technical / Maintenance forums, part of the General Discussion category; After driving for about 10 to 15 minutes the service engine soon light comes on my 92 GMC sierra 1500. ...
    Mar 2008
    baskin, la
    Question 92 Gmc Service Engine Soon
    After driving for about 10 to 15 minutes the service engine soon light comes on my 92 GMC sierra 1500. Where can i get the code read at? I went to one of the local parts house and they told me that they could only read 96 and up. If i cant get the code read what can i do to fix it.
    Registered User hornsfan10609's Avatar
    Aug 2006
    Austin Texas
    Re: 92 Gmc Service Engine Soon
    You can check your codes with a paperclip. You have to bend the paper clips so the ends of it are together, pointing the same way. Then find your OBD port under the driver's side dash and stick one end of the paper clip into pin a and the other into pin b. If you are looking at the plug it is the two on the right, on the row closer towards the seats. Stick the clip in there, turn your ignition to run 2, do not start it. The SES light should turn on and off, then will blink codes. They will be 2 digit codes, and it starts off with a 12 code, which is by default then it will read off all other trouble codes.
    91 RCSB C1500 4.3 4L60 Cash for Clunkered 8/3/09
    09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.35 @104.3
    94 Ford Mustang SVT Cobra ModdedSOLD 9/4/08
    Oct 2007
    TN
    Just like he said.
    I am going to post a pic of my Camaro, and Silverado.
    Your plug will look the same as my Camaro as it's an 89 and OBD I. You can also see the wire I used. You should use the same terminals.
    My 96 is just so you have an idea of what you are looking for and where. That plug will look slightly different.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Oct 2007
    TN
    Camaro
    Silverado
    05 Cavalier
    Mar 2008
    baskin, la
    thanks. I just bought the truck from a guy who is in really bad health for $1,000. there are a few scratches along the side and a dent on the hood where a tree limb fell on it, and the truck has 255,000 + miles but the motor was overhauled a little over a year ago. do you think i made a good deal or not?
    Oct 2007
    TN
    Not to bad.
    I would keep an eye out for problems. More likely in the suspension steering, just cause of the miles.
    Even the TBI's run a long time if taken care of.
    05 Cavalier
    Mar 2008
    baskin, la
    thats what im working on now i am in the process of bleeding the brakes because when i got the truck home and started a tune up I notice the the brake fluid resovior was extremely low. I got the truck for a project/work truck. not an everyday drive, I have an 2008 pontiac G6 for that.
    Oct 2007
    TN
    It should be a good truck.
    Probably just needs a little love here and there.
    05 Cavalier
    D to the MAX gr8shot's Avatar
    Jul 2008
    Grand Island, NE
    Yeah do the paperclip/wire trick. It will blink a code 12 three times, then each of your trouble codes three times each. My truck has a code 32 (egr), so it will blink 12 three times (one short blink, pause two short blinks, pause and it repeats two more times) Then it shows me the code 32 (three blinks, short pause two blinks, and repeats two more times).
    You can also try other parts stores. Here in NE AutoZone only carried OBDII readers, but Orilley's carries an OBDI reader, so If I'm close I'll go there usually since the reader tells you what the code means too.
    Good luck!! I think you got a good deal. My 92 has been GREAT!! I've never put a dime into the motor (except for a knock sensor) for the 100k I've owned it, and it's pushin towards 300k. They'll definently last if they're taken care of!!
    04 Chevy LB7 Dmax. Some go fast goodies from Husker Diesel
    SOLD!!!! 07.5 Chevy LMM Dmax DPF Deleted, EFI Live from Husker Diesel & more 448hp/834tq
    1992 Chevy 1500 ECSB 4x4 350TBI 320k miles
    '95 Chevy 2500 ECLB swapped in a 95 12v cummins, NV4500, 2wd
    Jul 2007
    Missouri
    post the code and ill tell you what it is..or pm me
    aka Denaliano 94BigBlazer's Avatar
    Jun 2005
    New York
    http://www.troublecodes.net/GM/
    GM OBD-1 Diagnostic Trouble Codes
    For 1995-previous model year EFI-equipped GM vehicles. NOTE: Some codes not supported on all models, consult your specific vehicle's service manual for the correct trouble code list and description for your application.
    DTC - 12 No distributor reference pulse (diagnostic test active)
    DTC - 13 Oxygen sensor circuit open or no activity
    DTC - 13 Left bank O2 sensor circuit open or no activity
    DTC - 14 Engine coolant temp sensor error (high temp indicated)
    DTC - 15 Engine coolant temp sensor error (low temp indicated)
    DTC - 16 System voltage too low
    DTC - 17 Camshaft position sensor error
    DTC - 21 Throttle Position sensor error (signal high)
    DTC - 22 Throttle position sensor error (signal low)
    DTC - 23 Intake air temp sensor error (low temp indicated)
    DTC - 24 Vehicle speed sensor error (open circuit or no activity)
    DTC - 25 Intake air temp sensor error (high temp indicated)
    DTC - 28 Auto transmission range pressure switch error
    DTC - 31 Wastegate solenoid circuit error
    DTC - 32 EGR system failure
    DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
    DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
    DTC - 35 IAC problem or idle error
    DTC - 36 MAF sensor error
    DTC - 36 24x Crankshaft position sensor circuit error
    DTC - 37 TCC brake switch circuit error
    DTC - 39 Clutch switch circuit error
    DTC - 41 Ignition control error
    DTC - 41 MEM-CAL error
    DTC - 41 CI Cam Sensor Signal error
    DTC - 42 Ignition bypass circuit error
    DTC - 43 Knock sensor error
    DTC - 44 Oxygen sensor error (lean condition indicated)
    DTC - 44 Left bank O2 sensor error (lean condition indicated)
    DTC - 45 Oxygen sensor error (rich condition indicated)
    DTC - 45 Left bank O2 sensor error (rich condition indicated)
    DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
    DTC - 51 PROM error
    DTC - 51 Incorrect MEM-CAL
    DTC - 52 Fuel cal-pak incorrect or missing
    DTC - 53 System voltage too high
    DTC - 54 Fuel pump circuit low voltage
    DTC - 55 ECM error
    DTC - 58 Trans fluid temp sensor circuit error (low voltage)
    DTC - 59 Trans fluid temp sensor circuit error (high voltage)
    DTC - 61 A/C system performance
    DTC - 63 Right bank O2 sensor circuit error
    DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
    DTC - 64 Right bank O2 sensor lean exhaust indicated
    DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
    DTC - 65 Right bank O2 sensor rich exhaust indicated
    DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
    DTC - 67 A/C pressure sensor circuit error
    DTC - 68 A/C clutch relay circuit error (shorted to ground)
    DTC - 69 A/C clutch relay circuit error (open circuit indicated)
    DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
    DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
    DTC - 72 VSS signal circuit error
    DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
    DTC - 75 Digital EGR solenoid #1 circuit error
    DTC - 76 Digital EGR solenoid #2 circuit error
    DTC - 77 Digital EGR solenoid #3 circuit error
    DTC - 79 Transmission fluid overtemp
    DTC - 80 Transmission component slipping
    DTC - 82 3x Crankshaft position sensor circuit error
    DTC - 85 PROM error
    DTC - 86 A/D error
    DTC - 87 EEPROM error (flash memory error)
    DTC - 90 TCC error
    DTC - 93 Transmission pressure control solenoid circuit error
    DTC - 96 Transmission system voltage low
    DTC - 98 Invalid PCM program
    DTC - 99 Invalid PCM program
    Aug 2005
    somewhere else
    Quote Originally Posted by trickedout420
    Please don't do troubleshooting in PM's, then nobody else can figure this stuff out by doing searches of the forums.
    Richard
    Mar 2008
    baskin, la
    as soon as i get the codes i will post them. im not all that worried about it because the truck runs fine. i just want to know why it comes on.
    Oct 2007
    TN
    Better to have it fixed so you know when something does go wrong, and it's easier to fix one problem over 5.
    05 Cavalier
    Mar 2008
    baskin, la
    just had the code read and it gave me, 32 egr failure. this is gonna be a first for me how would i replace it.
    Jul 2008
    Grand Island, NE
    My truck has been giving me that code for at least 3 years. I haven't ever fixed it. It never affects the truck at all, so I've just let it be lol.
    I think you have to replave the EGR valve, and clean out the passages in the intake to get it back up to par. Not positive since I haven't done mine, but someone else will either back me up or correct me. You might be able to clean out the egr valve and get it to work. Idk though since I haven't done mine.
