Results 1 to 5 of 5
1998 chevy 350 high idle
This is a discussion on 1998 chevy 350 high idle within the Technical / Maintenance forums, part of the General Discussion category; I have a 98 chevy 350 cpi with a very high idle at all time s but no ses lite?...
    Oct 2008
    Mi
    Oct 2008
    ILLINOIS
    Re: 1998 chevy 350 high idle
    There's a sensor in the throttle body that often gets covered in black deposits. Do a search for sensor cleaner or similar posts as yours. Good luck.
    Owner of all GM products 83Custom10's Avatar
    Sep 2007
    palm bay fl
    u can take it to the dealer and have it adjusted but have you added a k&n or exhaust?does your throttle ever stick?
    8.1L vortec 496ci big block avalanche with 6 inch lift 35 bfg mud terrians tuned .yea its quick an can haul almost anything click link to see my beast
    http://www.facebook.com/photo.php?pi...&id=1586263916[
    Can I help you? ksukats57's Avatar
    Oct 2007
    Kansas City
    Could be the IAC valve sticking
    2006 Tahoe Z71
    Dec 2005
    Linden, NC
    Have you checked for a vacuum leak? Take a can of carburetor cleaner and spray around the intake manifold, the TB, and all vacuum lines. If the engine speeds up, you'll have found your leak.
