Results 1 to 13 of 13
98 Chevy 350 cam timing
This is a discussion on 98 Chevy 350 cam timing within the Technical / Maintenance forums, part of the General Discussion category; so im trying to find for a friend cam timing on a 98 chevy 350? also was wondering if it ...
    Registered User chevyking4's Avatar
    Mar 2008
    Fort Worth, tx
    so im trying to find for a friend cam timing on a 98 chevy 350? also was wondering if it is the same as a 4.3 as close to 0 retard or advanced?
    0_o o_0 0_o o_0 98GreenMachine's Avatar
    Aug 2005
    St. Paul, MN
    Re: 98 Chevy 350 cam timing
    For a 98, the timing specification is called the cam retard offset and that value should be +/- 2 degrees of 0 at 1000 RPM.
    98 K1500 Z71 - 204k | L31 | 60E | 3.73's | 3" BL | 33x12.5x15 Dick Cepek F-C II's | Dynomax Ultra Flo X DI/DO | 14 MPG
    Mar 2008
    Fort Worth, tx
    hey thanks was that at 1000rpm's or 2000? the email i got when u replied said 2000rpms then when i looked at it on the forum it said 1000rpm's very weird never seen that happen
    Aug 2005
    St. Paul, MN
    sorry, I changed it. The RPM's need to be at least 1,000 for a accurate reading and adjustment.
    Mar 2008
    Fort Worth, tx
    ok just wanted to make sure but thanks a million!
    Aug 2005
    St. Paul, MN
    Do you have a Tech2 scanner that will read the value?
    Mar 2008
    Fort Worth, tx
    no i dont have one i just used the snap-on scanner at my old job whenever i need it lol but im going to check his timing with it to make sure thats what is wrong, before we take it to gm and pay 45 and they tell us that wasnt the prob and we dont get the money back
    Aug 2005
    St. Paul, MN
    cool deal, just making sure you realized you needed a scanner to adjust the timing, not a timing light
    Mar 2008
    Fort Worth, tx
    yea i knew but thanks for making sure lol also i know that the 02 4.3 is the same, but im really not sure at what rpm to check do you happen to? if not thats cool
    Oct 2004
    Woodstock Ontario Canada
    You can do the actual measurement at IDLE. Throw everything you ever thought you knew about timing a distributer out the window. It doesnt apply here.
    You just need to REV the engine over 1000rpm to reset the scan tool after EACH adjustment of the distributer.
    1)So you see what your scan tools reads for CMP retard.
    2)MAke an djustment via clocking the distributer
    3)Then REV teh engien over 1000 rpm with a quick jab of teh pedal or the t-body throttle arm, let engine idle again.
    read scan tool to see if CMP retard is within + or - 2.
    If its not, adjust, rev, read, adjust rev read.
    Basically revving the engine over 1000 rpm after EACH adjustment clears the previous reading.
    No need to hold an rpm, Thats old school distributer stuff.
    peace
    PAuly
    Aug 2005
    St. Paul, MN
    Quote Originally Posted by Pauly
    peace
    PAuly
    I didnt realize that, the GM service manuals just say to raise engine speed to 1000 rpms and check:
    TEST PROCEDURE
    The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
    1. With the ignition OFF, install a scan tool to the DLC.
    2. Start the engine and bring to normal operating temperature. IMPORTANT: Cam Retard Offset reading will not be accurate below 1000 RPM.
    3. Increase engine speed to 1000 RPM.
    4. Monitor the Cam Retard Offset.
    5. If the Cam Retard indicates a value of 0+/-2, the distributor is properly adjusted.
    6. If the Cam Retard does not indicate 0+/-2, the distributor must be adjusted.
    ADJUSTING PROCEDURE
    1. With the engine OFF, slightly loosen the distributor hold down bolt. IMPORTANT: Cam Retard Offset reading will not be accurate below 1000 RPM.
    2. Start the engine and raise engine speed to 1000 RPM.
    3. Using a scan tool monitor Cam Retard Offset.
    4. Rotate the distributor as follows:
    4.1. To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
    4.2. To compensate for a positive reading, rotate the distributor in the clockwise direction.
    5. Repeat step 4 until 0+/-2, is obtained.
    6. Turn the ignition OFF.
    7. Tighten the distributor hold-down bolt to 3 Nm (25 lb. ft.).
    8. Start the engine, raise engine speed to 1000 RPM and recheck Camshaft Retard Offset.
    Oct 2004
    Cool man, I didnt realize that. I am only quoting my personal experience. I kept clocking the dizzy 1 day and the CMP retard wouldnt change. Then I started revving the engine after each adjustment and was able to get a perfect 0 CMP retard.
    Thanks for the GM info.
    peace
    PAuly
    Mar 2008
    Fort Worth, tx
    yea great info to have!
