Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By diesel625
99 silverado Fuel Pump, 1 connector or 2?
This is a discussion on 99 silverado Fuel Pump, 1 connector or 2? within the Technical / Maintenance forums, part of the General Discussion category; I went to get a fuel pump from autozone today and they asked me if it had one connector or ...
    Registered User FTA.Boy's Avatar
    Nov 2006
    Colorado Springs
    I went to get a fuel pump from autozone today and they asked me if it had one connector or two.. I Was stumped. Anyway of telling? 1999 4wd 4.8l. It's probably the 1 connector because it's more expensive and NOT in stock... That's just the way the world works..
    LINK
    Every time I use 'Search' I find threads with my questions, but the only responses are assh0les telling the OP to use the search button... what the f*ck...
    1999 rcsb step side| 4.8->6.0 LQ4 swapped| 3" Summit BL & Rough Country Leveling kit| 315x75r16 Maxxis Bighorns
    Oct 2007
    TN
    Re: 99 silverado Fuel Pump, 1 connector or 2?
    You are better off getting a dealer pump. They cost more but last the longest.
    Other then calling the parts department at the dealer with your VIN I don't know what to tell you.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Nov 2006
    Colorado Springs
    dealer wants like 500-ish for a pump, F*ck that.
    Oct 2007
    TN
    They should at least be able to tell you if it's a one or two connector pump.
    05 Cavalier
    Registered User diesel625's Avatar
    May 2007
    college station, tx
    just get a delphi pump from oreilly's. they are just a few more dollars than everyone's house brand, and are brand new, not remans. to tell if it is one or two plug, just reach up on top of the tank to check. i did one on my brother's 01 last week and just put my arm up to the top of the tank and only felt one plug. it was an easy change with some help to drop the tank.
    PorkSword03 likes this.
    2004 Chevy 2500hd CCSB tuning, trans, 80HP Zex. daily driven at 500HP+.
    Registered User KTMRACER's Avatar
    Nov 2007
    Monroe, MI
    can also get a Delphi at Napa, I checked today and they wanted $330 for my dad's 2000 with a 5.3
    TRUST ME AUTOZONE PUMPS ARE CRAP!!! I'M ON MY 2nd AUTOZONE PUMP SINCE SPRING AND THIS ONE HAS ISSUES! I'm going to try to return it and then go to NAPA and get a delphi.
    2003 GMC Sierra RCSB 1500 2wd, 5.3L, 3.73s w/ g80 locker
    Stock 98 C1500 RCLB Vortec 305
    Aug 2007
    Verona, PA
    I just sucked it up and went with a dealer pump. After giving them a Sob story, they knocked it down to $415.00 pre-tax. It also came with the new style wiring harness that needs to be spliced in. I have an '02 with a 4.8L and just did this about a month ago.
    Almost every search on this forum results in get an AC Delco pump if you want it to last.
    2002 GMC Sierra 4.8 RCLB 4x4 - Blackbear Tune
    Aug 2007
    Verona, PA
    Oh, and the pump was the entire sending unit assembly, so it had 2 connectors. One for the pump and one for the sender.
