Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 271
Can someone please decode my VIN?
This is a discussion on Can someone please decode my VIN? within the Technical / Maintenance forums, part of the General Discussion category; robwetzel VIN : 3GCFK23Y59G192929 VEHICLE INFORMATION Merchandising Model : CK10543 -2009 SILVERADO 1500 4WD CREW CAB LT1 Warranty Start Date ...
  1. #141
    2nd Amendment Supporter mudbuddy's Avatar
    Sep 2007
    S.E. Wi.
    Re: Can someone please decode my VIN?
    robwetzel
    VEHICLE INFORMATION
    Merchandising Model : CK10543 -2009 SILVERADO 1500 4WD CREW CAB LT1 Warranty Start Date : 03/28/2009
    BARS Order Type : 70 - RETAIL - STOCK
    Delivering Dealer : MURDOCK CHEVROLET, INC.
    2375 S 625 W
    WOODS CROSS , UT 84010-8182
    (801) 298-8090
    Selling Source : 13 - CHEVROLET
    Site Code : 36475
    Business Associate Code : 113129
    Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
    REQUIRED FIELD ACTIONS
    Vehicle Has No Current Record Of Outstanding Campaigns
    SERVICE INFORMATIONAL ITEMS
    Type Number Description Posted Date Status
    EI 09081 BODY MOUNTED WEATHER STRIP REPLACEMENT (REF. TSB 09-08-64-012) 04/01/2009 See Bulletin
    EI 09085 FRONT SUSPENSION CLUNK, SQUEAK, RATTLE POPPING OR CREAK (REF TSB 09-03-08-006) 04/22/2009 See Bulletin
    EI 09117 RADIO INOPERATIVE OR NO DISPLAY(REF. TSB 09-08-44-012) 05/15/2009 See Bulletin
    EI 09142 PAINT APPEARANCE, DIRT/ORANGE-PEEL/THIN,BLEED THRU/RUNS (REF. PIE 0005) 08/12/2009 See Bulletin
    EI 09215 REMOTE KEYLESS ENTRY (RKE) REPROGRAMMING (REFERENCE PIE 0014) 09/17/2009 See Bulletin
    EI 09257 STABILITRAK INOPERATIVE (REFERENCE PIE 0021) 10/07/2009 See Bulletin
    ON STAR AND XM SATELLITE RADIO INFORMATION
    OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
    XM Equipped Yes XM Radio ID 1GV932W1 XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
    APPLICABLE WARRANTIES
    Description Effective Date Effective Odometer End Date End Odometer
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/28/2009 12 miles 03/28/2012 36012 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/28/2009 12 miles 03/28/2015 100012 miles
    60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 03/28/2009 12 miles 03/28/2014 100012 miles
    96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/28/2009 12 miles 03/28/2017 80012 miles
    36/36000 FEDERAL EMISSION 03/28/2009 12 miles 03/28/2012 36012 miles
    CLAIM HISTORY
    R.O Date R.O Number Type Labor Operation Odometer Reading
    07/06/2009 073426 # B4000 - FRONT SIDE DOOR ADJUSTMENT - RIGHT SIDE 3217 miles
    07/06/2009 073426 # C3348 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 3217 miles
    07/06/2009 073426 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 3217 miles
    07/06/2009 073426 # Z7902 - 2-DAY COURTESY TRANSPORTATION 3217 miles
    02/11/2009 A92929 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    VIN 3GCFK23Y59G192929
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 3314 kg (7307 lb) Order Number : NGHCHC
    Build Date : 02/11/2009 Build Plant : 39G43
    GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    OPTION CODES
    AG1 - SEAT ADJUSTER-DRIVER SIDE 6-WAY
    AJ1 - DEEP TINTED GLASS
    AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
    AM1 - MANUAL LUMBAR, DRIVER
    AP3 - REMOTE VEHICLE START
    AT8 - RESTRAINT CHILD PROVISIONS
    AU3 - POWER DOOR LOCKS WITH REMOTE KEYLESS ENTRY
    AXN - 9.5 LIGHT DUTY BEAM
    AZ3 - 40/20/40 SPLIT BENCH LEATHER APPOINTED SEATING SURFACES WITH 6-WAY POWER DRIVER SEAT ADJUSTER
    A31 - POWER WINDOWS
    A48 - POWER SLIDING REAR WINDOW (DELETES REAR WINDOW DEFOGGER)
    A60 - LOCKING TAILGATE WITH EZ LIFT
    A68 - SEAT, 60/40 REAR FOLDING BENCH
    B30 - CARPETING, COLOR-KEYED
    B32 - FRONT COLOR-KEYED FLOOR MATS
    B33 - REAR COLOR KEYED FLOOR MATS
    B85 - BODY SIDE MOLDING
    CJ2 - DUAL-ZONE AUTO AIR CONDITIONING
    C6A - GVW RATING - 7,300 LBS
    DD8 - INSIDE REARVIEW MIRROR, AUTO- DIMMING
    DH6 - LIGHTED VISOR/VANITY MIRRORS
    DK8 - DELUXE OVERHEAD CONSOLE
    DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL (REPLACES STD/PKG MIRROR)
    EF7 - U.S. COUNTRY CODE
    E63 - FLEETSIDE BODY
    FE9 - 50-STATE EMISSIONS
    FUB - SEALER
    GT4 - REAR AXLE - 3.73 RATIO
    G80 - LOCKING REAR DIFFERENTIAL
    JD9 - BRAKES, 17" DISC/DISC
    JL4 - STABILITRAK-STABILITY CONTROL W/ TRACTION CONTROL SYSTEM
    KC4 - ENGINE OIL COOLING SYSTEM
    KG3 - 145 AMP ALTERNATOR
    KNP - HD AUX TRANS. COOLING SYSTEM
    K34 - CRUISE CONTROL
    L76 - VORTEC 6.0L V8 SFI ENGINE W/ ACTIVE FUEL MANAGEMENT 6-SPEED AUTOMATIC TRANSMISSION
    MSL - SILAO, MEXICO PLANT
    MYC - 6-SPEED AUTOMATIC TRANSMISSION
    NHT - MAX TRAILERING PACKAGE: * VORTEC 6.0L V8 SFI ENGINE W/ ACTIVE FUEL MANAGEMENT * 6-SPEED AUTOMATIC TRANS * TOWING PACKAGE * LOCKING REAR DIFFERENTIAL * HEAVY DUTY TRAILERING AXLE * FRONT/REAR DISC BRAKES * 17" CUSTOM ALUMINUM WHEELS * ON/OFF ROAD BW TIRES (REPLACES STD/OPT CONTENT)
    NP5 - LEATHER WRAPPED STEERING WHEEL
    NQH - TRANSFER CASE
    NT7 - EMISSION SYSTEM FEDERAL TIER 2
    NZ4 - FULL SIZE SPARE WHEEL
    N56 - 17" CUSTOM ALUMINUM WHEELS
    PCM - INTERIOR PLUS PACKAGE: * AUTO DUAL ZONE A/C * STEERING WHEEL RADIO CONTROLS * BLUETOOTH FOR PHONE PDD - EXTERIOR PLUS PACKAGE: * FOG LAMPS * REMOTE VEHICLE STARTER SYS * LOCKING TAILGATE * EZ LIFT TAILGATE * UNIVERSAL HOME REMOTE * ISRV MIRROR W/AUTO DIMMING * OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL (REPLACES STD/OPT MIRROR)
    PPA - EZ LIFT TAILGATE
    QJP - ON/OFF ROAD BW TIRES
    ROO - BARS VOMS BAILMENT
    R4Y - TIRE BRAND-GOODYEAR
    R9N - PROCESSING CODE
    R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
    SAF - SPARE TIRE LOCK
    SLM - STOCK ORDERS
    SSB - PROCESSING OPTION
    T74 - HEADLAMPS
    T96 - FOG LAMPS
    UE1 - 1YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
    UG1 - UNIVERSAL HOME REMOTE
    UJ6 - TIRE PRESSURE MONITOR
    UK3 - STEERING WHEEL RADIO CONTROLS
    UPF - BLUETOOTH FOR PHONE
    UQ3 - ENHANCED AUDIO SPEAKERS
    US8 - AM/FM STEREO WITH CD PLAYER
    U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
    VB3 - CHROME REAR BUMPER
    VG3 - FRONT BUMPER
    VH9 - ENVELOPE OWNER INFO MANUAL
    VK3 - FRONT LICENSE PLATE MOUNT
    VR4 - WEIGHT DISTRIB. PLATFORM HITCH
    VT7 - OWNERS MANUAL ENGLISH
    VXS - COMPLETE VEHICLE LABEL
    V22 - CHROME GRILLE
    V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
    V76 - RECOVERY HOOKS
    X88 - CHEVROLET CONVERSION
    YD3 - BASE AXLE
    YD5 - BASE FRONT SPRING
    YD6 - BASE REAR SPRING
    YE9 - SILVERADO
    ZRS - 17" SPARE TIRE
    ZY1 - SOLID PAINT
    Z82 - HD TRAILERING EQUIPMENT
    Z85 - HEAVY DUTY SUSPENSION
    1LT - SILVERADO LT1 EQUIPMENT GROUP
    1SZ - OPTION PKG DISCOUNT
    19I - EBONY 193 - EBONY
    46U - BLUE GRANITE METALLIC
    6UW - COMP FRT LH COMPUTER SEL SUSP
    7UW - COMP FRT RH COMPUTER SEL SUSP
  2. #142
    Sep 2007
    S.E. Wi.
    louisianagmfs
    VIN : 2GTEK13TX61250421
    VEHICLE INFORMATION
    Merchandising Model : TK15543 -2006 SIERRA 1500 4WD CREW CAB SLT Warranty Start Date : 05/25/2006
    Delivering Dealer : LOUISIANA MOTORS CADILLAC-GMC TRUCK
    900 E SIMCOE ST
    LAFAYETTE , LA 70501-4529
    (337) 233-6411
    Selling Source : 48 - GMC TRUCK
    Site Code : 51259
    Business Associate Code : 218947
    Vehicle Has No Current Record Of Outstanding Service Information
    OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
    XM Equipped Yes XM Radio ID 16BUD0M4 XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/25/2006 25 miles 05/25/2009 36025 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/25/2006 25 miles 05/25/2012 100025 miles
    96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/25/2006 25 miles 05/25/2014 80025 miles
    36/36000 FEDERAL EMISSION 05/25/2006 25 miles 05/25/2009 36025 miles
    CLAIM HISTORY
    02/29/2008 516254 # E2327 - FRONT WHEEL BEARING AND HUB REPLACEMENT - BOTH SIDES 35979 miles
    02/29/2008 516254 # T2020 - TOWING 35979 miles
    08/22/2007 512154 # J6441 - EVAPORATIVE EMISSION CANISTER VENT SOLENOID VALVE REPLACEM 25744 miles
    01/14/2006 500864 I Z6999 - PDI RELATED FLUID ADDS 4 miles
    12/19/2005 A50421 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    VIN 2GTEK13TX61250421
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : JRDJ9G
    Build Date : 12/19/2005 Build Plant : 26143
    OPTION CODES
    AG1 - POWER DRIVER SEAT ADJUSTER
    AG2 - POWER FRONT SEAT ADJUSTERS
    AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
    AM7 - FOLDING REAR SEAT
    AN3 - FRT FULL-FEATURE RECLINING BUCKET SEATS - LEATHER
    AU0 - REMOTE KEYLESS ENTRY SYSTEM
    A31 - POWER WINDOWS
    B30 - FULL-COLOR KEYED CARPET W/MATS
    B33 - REAR COLOR-KEYED FLOOR MATS
    B71 - WHEEL FLARES
    B85 - BRIGHT BODY SIDE MOLDINGS
    CJ2 - DUAL ZONE AIR COND - AUTO
    C49 - ELECTRIC REAR WINDOW DEFOGGER
    C5W - GVW RATING - 7,000 LBS
    DF5 - ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP
    DK7 - OVERHEAD CONSOLE
    DL3 - OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTRO- CHROMIC DR-SIDE MIRROR
    DT4 - SMOKER'S PACKAGE
    D07 - FLOOR CONSOLE
    EVA - EVAP EMISSION REQUIREMENT
    E63 - WIDESIDE BOX PICKUP BED
    FF6 - TORSION BAR SPRING ADJ - LH
    FF7 - TORSION BAR SPRING ADJ - RH
    G80 - H.D. REAR LOCKING DIFFERENTIAL
    JF3 - POWER DISC BRAKES W/ABS
    JJG - FRT END SUBASSEMBLY
    KG3 - ALTERNATOR 145 AMP
    KNP - H.D. TRANSMISSION OIL COOLER
    KUP - THROTTLE CONTROL ELECTRONIC
    K47 - HIGH CAPACITY AIR CLEANER
    LM7 - VORTEC 5.3L 295HP IRON BLK V8
    M30 - 4-SPD AUTO TRANS W/ OVERDRIVE
    NP5 - LEATHER-WRAPPED STEERING WHL
    NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
    NT8 - FEDERAL EMISSION SYSTEM
    NZZ - OFF-ROAD SKID PLATE PKG
    OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
    PDB - ONSTAR PLUS PACKAGE INCLUDES: *XM SATELLITE RADIO - SERVICE FEE EXTRA - 1ST 3 MONTHS INCL. *ONSTAR SERVICE - INCLUDES 1 YEAR SAFE & SOUND PLAN
    PDU P27 - 17" POLISHED CAST ALUM. WHEELS
    QJM - P265/70R17 OOR WOL TIRES
    R5C - TIRE BRAND ALL BRIDGESTONE
    R6P - PREMIUM PAINT
    R9N - LEATHER SEAT TRIM
    SLM - STOCK ORDERS
    SSB TFE - SALES INCENTIVE-COMMITMENT PLUS
    TSM T96 - FRONT FOG LAMPS
    UC6 - AM/FM STEREO W/6-DISC CD CHANGER (REPLACES STD/OPT RADIO)
    UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN
    UK6 - REAR SEAT AUDIO CONTROLS
    UQ7 - BOSE PREMIUM SPEAKER SYSTEM
    U2K - *XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
    VB3 - CHROME STEP REAR BUMPER
    VG3 - CHROME FRONT BUMPER
    VR4 - WEIGHT DIST HITCH PLATFORM
    V22 - CHROME GRILLE SURROUND
    V73 - STATEMENT OF CERT. U.S.
    XJM - P265/70R17-113S WOL TIRE
    YD3 - BASE EQUIP FOR SCH GVW PLATE
    YD5 - FRONT SPRING - BASE EQUIPMENT
    YD6 - REAR SPRING - BASE EQUIPMENT
    YE9 - SLE/SLT DECOR
    YJM - P265/70R17 - 113S WOL TIRE
    ZJP - P265/70R17-113S BW SPARE TIRE
    ZY1 - SOLID PAINT
    Z82 - H.D. TRAILERING EQUIPMENT PKG.
    Z85 - HANDLING/TRAILERING SUSP PKG
    Z88 - GMC TRUCK NAMEPLATE
    1SZ - POWER PACK SAVINGS
    16U - STEEL GRAY METALLIC 4SA - SLT DECOR INCLUDES: *PWR FRT/PASS 10-WAY SEAT ADJUSTER *ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP *ELECTRIC REAR WINDOW DEFOGGER *DEEP TINTED GLASS *AM/FM STEREO W/6-DISC CD PLAYER *BOSE PREMIUM SPEAKER SYSTEM *REAR AUDIO CONTROLS *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTRO- CHROMIC DR-SIDE MIRROR *LEATHER-WRAPPED STEERING WHEEL *FRONT FOG LAMPS *CHROME GRILLE *BODYSIDE MOLDINGS *ALUMINUM WHEELS *AUTOTRAC TRANSFER CASE
    6YT - COMPONENT FRT LH COMPUTER SEL SUSP
    69I - DARK PEWTER INTERIOR TRIM
    692 - DARK PEWTER
    7YT - COMPONENT FRT RH COMPUTER SEL
  3. #143
    Sep 2007
    S.E. Wi.
    OK enough for tonight I am tired I'll work on the rest of you guys by this weekend.
  4. #144
    Registered User 951500's Avatar
    Sep 2007
    atlantic canada
    Hey , if you ever get the chance is it posible to run mine , i bought my 05 z71 last winter and would love to get some history on it , if you can that be great if not thats not a problem , thanks.
    1GCEK19V65E176517
  5. #145
    Registered User CChase's Avatar
    Nov 2006
    New England
    Hmm, wonder what mine says: 1GCEC14H6PE107215
    1993 C1500, 5.0L, 372,000mi
    2006 GTO, 22,000mi
  6. #146
    Registered User K1500Tech's Avatar
    Jun 2007
    Texas
    95 1500
    VIN : 1GCEK19V65E176517
    CLAIM HISTORY
    Repair Order Date : 04/28/2006 Repair Order Number : 778541 Odometer Reading : 7605 kilometres
    Serviced By : LOUNSBURY COMPANY LIMITED
    PO BOX 356
    NEWCASTLE, NB E1V1P9
    (506) 622-2311 Selling Source : 14 - GM OF CANADA
    Site Code : 87116
    Business Associate Code : 121143
    Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
    05/05/2006 688 01 # B1783 - WINDSHIELD WIPER BLADE REPLACEMENT 89000980 N
    Repair Order Date : 11/04/2005 Repair Order Number : 753642 Odometer Reading : 93 kilometres
    PO BOX 356
    Site Code : 87116
    11/22/2005 641 01 # E3300 - FRONT TORSION BAR ADJUSTMENT N/A N
    Repair Order Date : 11/23/2004 Repair Order Number : 702794 Odometer Reading : 18 kilometres
    PO BOX 356
    Site Code : 87116
    11/26/2004 538 01 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 12450108 N
    Repair Order Date : 11/10/2004 Repair Order Number : 701039 Odometer Reading : 10 kilometres
    PO BOX 356
    Site Code : 87116
    12/14/2004 543 01 T A2465 - BOX, PICKUP SIDE EXTERIOR (BETWEEN TOP OF BOX AND BREAK LI 15758148 Y
    Repair Order Date : 10/29/2004 Repair Order Number : A76517 Odometer Reading : 0 kilometres
    PO BOX 356
    Site Code : 87116
    11/02/2004 531 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
    2009 General Motors. All Rights Reserved.
    VIN 1GCEK19V65E176517
    VEHICLE BUILD
    Merchandising Model : CK15753 -2005 SILVERADO LS STANDARD BOX 4WD
    Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : M49353
    Build Date : 10/29/2004 Build Plant : 15E53
    OPTION CODES
    AE7 - 40/20/40 FRONT SPLIT BENCH SEAT AJ1 - DEEP TINTED REAR GLASS
    AL0 AM7 - 60/40 SPLIT FOLDING REAR SEAT
    AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS
    A31 - POWER WINDOWS AND DOOR LOCKS BVE - TUBULAR SIDE STEPS, CHROME
    B30 - FLOOR CARPETING B32 - FRONT AND REAR FLOOR MATS
    B33 - REAR FLOOR MATS B71 - FENDER FLARE MOULDINGS
    B85 - BODY SIDE MOULDINGS CJ3 - AIR CONDITIONING, DUAL ZONE
    C49 - REAR WINDOW DEFOGGER C7H - GVWR: 2903 KG (6400 LB)
    DF5 - ELECTROCHROMIC ISRV MIRROR DK7
    DL8 - DUAL ELECTRIC HEATED MIRRORS DNR - RPA IDENTIFIER
    EVA E63 - FLEETSIDE BODY OPTION
    FE9 - FEDERAL CERTIFICATION EMISSION FK2
    FK3 GMC
    GU6 - 3.42 REAR AXLE RATIO G80 - AXLE - LOCKING RR. DIFFERENTIAL
    JF7 KG3
    KUP - ENGINE PTO CONTROL VARIABLE SPEED K05 - HEATER - ENGINE BLOCK
    K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
    LR4 - VORTEC 4800 SFI V8 ENGINE M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE
    NP5 - LEATHER WRAPPED STEERING WHEEL NP8 - AUTOTRAC - AUTOMATIC 4WD
    NT9 NZZ - OFF-ROAD SKID PLATE PACKAGE
    P25 - 17" 5-SPOKE ALUMINUM WHEELS (4) QJP - TIRES - P265/70R-17" OOR BW (4)
    R5C R6M - FLEETSIDE APPEARANCE PACKAGE
    R7K R7M - VEHICLE INVOICE CREDIT
    R9Z SAF - SPARE TIRE LOCK
    SLM TR3 - COLOUR-KEYED GRILLE
    T96 - FRONT FOG LAMPS UB0 - RADIO - CD PLAYER, RDS, ATC
    UQ3 - PERFORMANCE ENHANCED AUDIO 6 SPEAKER SYSTEM U19 - KILO SPEEDOMETER
    VB3 - CHROME REAR STEP BUMPER VCG
    VG3 - CHROME FRONT BUMPER VXS
    V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XJP
    X88 YD3
    YD6 - REAR SPRING BASE EQUIPMENT YE9 - SILVERADO LS MODEL
    YJP ZJP
    ZY1 - SOLID PAINT Z49 - CANADIAN BASE EQUIPMENT
    Z71 - OFF-ROAD CHASSIS EQUIPMENT 1SD - PREFERRED EQUIPMENT GROUP
    6YH 62U - DARK GRAY METALLIC
    69D - DARK CHARCOAL 69I
    7YH
    Katzkin leather interior, 2" CCM Off road leveling kit, Ranch Hand grill guard, and Ranch Hand rear bumper.
  7. #147
    Sep 2007
    atlantic canada
    Quote Originally Posted by K1500Tech View Post
    95 1500
    CLAIM HISTORY
    PO BOX 356
    Site Code : 87116
    PO BOX 356
    Site Code : 87116
    PO BOX 356
    Site Code : 87116
    PO BOX 356
    Site Code : 87116
    PO BOX 356
    Site Code : 87116
    VEHICLE BUILD
    OPTION CODES
    FK3 GMC
    JF7 KG3
    X88 YD3
    YJP ZJP
    7YH
    Thank you verry Much , that was fast .
  8. #148
    Sep 2007
    S.E. Wi.
    Cheyenne88 sorry no info
  9. #149
    Registered User the big d's Avatar
    Nov 2008
    Georgia
    Can I get a decode on our old fsc
    1gcgc24rxxr726481
    2000 Chevrolet K2500 454
    2004 Pontiac GTO
  10. #150
    Member RTCamaroSS's Avatar
    Jan 2004
    Fremont, Ca
    Quote Originally Posted by RTCamaroSS View Post
    Can someone please decode my VIN for me? Im looking for any information i can get, service history, options, etc. Can you please email the information to me, as i dont check the board often (RTCamaroSS@aol.com). Thank you!
    1996 GMC Sierra 1500 Z71 5.7L
    1GTEK19R5TE509788
    Any chance i get my vin run?
    Current vehicles:
    08 Lexus IS250 - FSport.
    10 Toyota Sienna Limited - Wife's.
    96 GMC Sierra Z71 - Lift, Nav, Etc.
    93 Mazda RX7 - LS1/T56 Project
    Sold Vehicles:
    93 GMC Sierra Z71 - Lift, Etc.
    87 Chevy V10 - Lift, Stereo, Etc.
    99 Camaro SS - 600+rwhp, low 10's.
    98 Lexus GS400 - Lots of mods.
  11. #151
    Sep 2007
    S.E. Wi.
    I don't do emails or pm's, maybe someone else does and my system doesn't have info on 97-98 or older models.
  12. #152
    Sep 2007
    S.E. Wi.
    RT here ya go
    VIN : 1GTEK19R5TE509788
    VEHICLE INFORMATION
    Merchandising Model : TK10753 -1996 4X4 SIERRA CLUB COUPE SWB P/U Warranty Start Date : 12/30/1995
    BARS Order Type : 60 - RETAIL - SOLD
    Delivering Dealer : GILROY PONTIAC BUICK GMC
    112 VOLCANO RIDGE
    GRANITE BAY , CA 95746-6771
    (408) 842-3171
    Site Code : 40114
    Business Associate Code : 117731
    RC 03023 WINDSHIELD WIPER MOTOR FAILURES 05/20/2003 Open
    Vehicle Has No Associated On Star or XM Radio Information.
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/30/1995 325 miles 12/30/1998 36325 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/30/1995 325 miles 12/30/2001 100325 miles
    96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/30/1995 325 miles 12/30/2003 80325 miles
    84/70000 CALIFORNIA SELECT COMPONENT 12/30/1995 325 miles 12/30/2002 70325 miles
    36/50000 CALIFORNIA EMISSIONS 12/30/1995 325 miles 12/30/1998 50325 miles
    VIN 1GTEK19R5TE509788
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 2817 kg (6211 lb) Order Number : T29410
    Build Date : 11/30/1995 Build Plant : 1TE53
    OPTION CODES
    AG9 - 6 WAY POWER SEAT ADJUSTER
    A20 - SWING OUT REAR QUARTER WINDOW
    A28 - SLIDING REAR WINDOW
    A31 - POWER WINDOWS
    A95 - HI-BACK RECLINING BUCKET SEATS
    BZY - PICKUP BOX BEDLINER
    B96 - BRIGHT WHEEL OPENING MOLDINGS
    C60 - AIR CONDITIONING
    D48 - DUAL ELECT REMOTE CONT MIRRORS
    D55 - FLOOR CONSOLE
    E63 - WIDESIDE BODY
    FK2 - TORSION BAR SPRING ADJ - LH
    FK3 - TORSION BAR SPRING ADJ - RH
    GMC - ASSEMBLY PLANT-PONTIAC, MICH.
    GU6 - REAR AXLE - 3.42 RATIO
    JB5 - VAC POWER DISC/DRUM BRAKES
    KC4 - ENGINE OIL COOLER
    K34 - ELECTRONIC SPEED CONTROL
    K60 - GENERATOR 100 AMP
    L31 - VORTEC 5700 V8 SFI GAS ENGINE
    M30 - 4-SPEED AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
    NA1 - EMISSION SYSTEM - LIGHT DUTY
    NB6 - CALIFORNIA EMISSION SYSTEM
    NG5 - 50 STATE EMISSION CERTIFICATE
    NP1 - ELECTRONIC SHIFT TRANSFER CASE
    NP5 - LEATHER WRAPPED STEERING WHL
    NRQ - EXHAUST CLOSE COUPLED
    NZZ - OFF ROAD - SKID PLATE
    N33 - COMFORTILT STEERING WHEEL
    PF4 - CAST ALUMINUM WHEELS 16X7
    Q4B - GVW RATING - 6200 LB
    RSA - PASSIVE AUTO FRT SEAT RESTRAINT
    SLL - PROCESSING OPTION-SOLD ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS
    UL0 - RADIO ETR AM/FM STEREO CASSETTE WITH THEFT LOCK, AUTOMATIC TONE CONTROL, SEEK & SCAN, AND CLOCK
    UQ3 - ENHANCED PERFORMANCE SPEAKERS
    VB3 - CHROME RR STEP BUMPER
    VG3 - CHROME FRT BUMPER W/ RUB STRIP
    VG8 - BUYER NOTICE LABEL
    VP6 - NOISE CONTROL
    V22 - DELUXE FRONT APPEARANCE
    XGD - P265/75R16 ALL TRN SB RAD WOL-F
    YA7 - CALIF. ASSY. LINE EMISSION TEST
    YE9 - SLE DECOR INCLUDES THE FOLLOWING: - DELUXE FRT APPEARANCE PKG. - POWER DOOR LOCKS & WINDOWS - LEATHER WRPD STEERING WHL
    YF5 - 50 STATE EMISSIONS
    YGD - P265/75R16 ALL TRN SB RAD WOL-R
    ZGD - P265/75R16 ALL TRN SB RAD WOL-S
    ZQ3 - TILT WHEEL AND SPEED CONTROL
    ZY1 - SOLID COLOR
    Z71 - OFF-ROAD CHASSIS EQUIP PACKAGE
    Z82 - HEAVY DUTY TRAILERING EQUIPMENT
    Z88 - GMC NAMEPLATE
    1SC - MARKETING OPTION PACKAGE REJECT
    1SZ - MKTG OPTION PKG DISCOUNT
    13D - GRAY - CUSTOM CLOTH
    13I - GRAY INTERIOR TRIM
    27U - 27 MET LT STELLAR BLUE-SOLID
    6GG - SPRING COMPTR SELECT FRT LH
    7GG - SPRING COMPTR SELECT FRT RH
  13. #153
    Sep 2007
    S.E. Wi.
    the big d
    VIN : 1GCGC24RXXR726481
    VEHICLE INFORMATION
    Merchandising Model : CC20903 Warranty Start Date : 03/13/2000
    Delivering Dealer : SIMPSONVILLE CHEVROLET, INC.
    P O BOX 4357
    TROY , MI 48099-4357
    (864) 271-7771
    Site Code : 16080
    Business Associate Code : 164498
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/13/2000 778 miles 03/13/2003 36778 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/13/2000 778 miles 03/13/2006 100778 miles
    60/50000 FEDERAL EMISSION 03/13/2000 778 miles 03/13/2005 50778 miles
    CLAIM HISTORY
    07/20/1999 R26481 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    GM Vehicle Inquiry System
    Vehicle Build
    Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
    Help
    VIN 1GCGC24RXXR726481
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 3904 kg (8608 lb) Order Number : BPJZ24
    Build Date : 07/20/1999 Build Plant : 1XR03
    ARL A52
    C6P C60
    DE2 E63
    FE9 GT4
    G80 JB7
    KNP K34
    K60 L31
    MT1 NA4
    NF2 N33
    R7H R9A
    R9Z SLM
    UM6 UQ5
    VK3 VR4
    VXS V43
    V73 XHH
    X88 YD3
    YD6 YHH
    ZHH ZQ3
    ZY1 Z82
    1SA 1SZ
    13I 13V
    50U 6XA
    7XA
    Sometimes the codes are just the codes and no explanation to what they are I don't have time to decode each one but you can do it from the rpo code list sticky.
  14. #154
    Sep 2007
    S.E. Wi.
    cchase sorry man
    VIN 1GCEC14H6PE107215
    VEHICLE BUILD
    Vehicle Option Information Not Available
  15. #155
    Sep 2007
    S.E. Wi.
    Did I miss anyone and thanks to the other guys helping out posting the info.
  16. #156
    Registered User chevysol's Avatar
    Oct 2009
    Alabama
    could you do mine?
    1GCEC14W92Z139849
    thanks
  17. #157
    Sep 2007
    S.E. Wi.
    chevysol here ya go.
    VIN : 1GCEC14W92Z139849
    VEHICLE INFORMATION
    Merchandising Model : CC15703 -2002 SILVERADO LS 1500 2WD REG CAB Warranty Start Date : 12/28/2001
    Delivering Dealer : BILL HEARD CHEVROLET CADILLAC
    3615 MANCHESTER EXPY
    COLUMBUS , GA 31909-5360
    (706) 322-8888
    Site Code : 08276
    Business Associate Code : 112516
    RC 04007 TAILGATE SUPPORT CABLE N/A Closed
    RC 05500 IGNITION DISTRIBUTOR SYSTEM CORROSION - INSPECT / REPLACE N/A Closed
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/28/2001 12 miles 12/28/2004 36012 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/28/2001 12 miles 12/28/2007 100012 miles
    96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/28/2001 12 miles 12/28/2009 80012 miles
    36/36000 FEDERAL EMISSION 12/28/2001 12 miles 12/28/2004 36012 miles
    CLAIM HISTORY
    12/02/2005 544875 # V1351 - 05500 - INSPECT VENT HOLES FOR EIP SCREENS- REPLACE DISTRI 43737 miles
    12/10/2004 506375 # D1002 - BLOWER MOTOR RESISTOR REPLACEMENT 31258 miles
    12/10/2004 506375 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 31258 miles
    12/10/2004 506375 # E3020 - SPRINGS, FRONT COIL - RIGHT - REPLACE 31258 miles
    05/12/2003 429846 # T2020 - TOWING 17494 miles
    05/03/2003 443600 # J4360 - CAP, DISTRIBUTOR - REPLACE 17494 miles
    09/06/2001 A39849 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    VIN 1GCEC14W92Z139849
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 2769 kg (6106 lb) Order Number : DPCNF0
    Build Date : 09/06/2001 Build Plant : 12Z03
    OPTION CODES
    AG1 - SIX-WAY POWER DRIVER SEAT
    AG2 - 6-WAY POWER DRIVER & PASS SEATS
    AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
    AU3 - POWER DOOR LOCK SYSTEM
    A31 - POWER WINDOWS
    A95 - RECLINING BUCKET SEATS
    B30 - WHEELHOUSING & FLOOR CARPETING
    C5M - 6,100 LB GVW RATING
    C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
    DK7 - INTERIOR CUSTOM ROOF CONSOLE
    D48 - ELECTRIC EXTERIOR MIRRORS
    D55 - CONSOLE
    FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
    FWI - FORT WAYNE PLANT
    GU6 - REAR AXLE 3.42 RATIO
    JC5 - 4 WHEEL POWER DISC BRAKES
    K68 - 105 AMP DELCOTRON GENERATOR
    L35 - VORTEC 4300 V6 SFI ENGINE
    M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
    NF2 - FEDERAL EMISSION SYSTEM
    PDD - COLOR-KEYED CARPET
    PF9 - CAST ALUMINUM WHEELS
    QNG - P235/75R16 ALS WOL TIRES
    SLM - STOCK ORDERS
    UN0 - AM/FM STEREO W/CD PLAYER & ATC
    VG3 - FRONT DELUXE CHROMED BUMPER
    V22 - DELUXE FRONT APPEARANCE PKG.
    XNG - P235/75R16-106S ALS WOL TIRES
    YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
    YE9 - SILVERADO
    YNG - P235/75R16-106S ALS WOL TIRES
    ZNG - P235/75R16-106S ALS WOL TIRES
    ZY1 - SOLID PAINT
    Z83 - STANDARD CHASSIS PACKAGE
    1SB - LS DECOR INCLUDES: * AIR CONDITIONING W/AIR FILTRATION SYSTEM * DUAL POWER MIRRORS * CHROME GRILLE * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS * 40/20/40 SEATING W/RECLINE AND ARMREST STORAGE
    1SZ - PREFERRED EQUIPMENT SAVINGS (NOTE-THIS PREFERRED EQUIPMENT GROUP SAVINGS IS RESTRICTED TO RESIDENTS OF TEXAS, OKLAHOMA, LOUISIANA AND SELECT COUNTIES IN NEW MEXICO. PLEASE CONSULT YOUR DEALER FOR ELIGIBILITY REQUIREMENTS.)
    12D - GRAPHITE CUSTOM CLOTH TRIM
    12I - GRAPHITE INTERIOR TRIM
    14U - MED CHARCOAL GRAY METALLIC
    6MS - COMPONENT FRT LH COMP. SEL SUSP
    7MS - COMPONENT FRT RH COMP. SEL SUSP
  18. #158
    Oct 2009
    Arkansas
    If it is not to much trouble If you would do mine I would Appreciate it.
    1GCGK23U147188565
    Thank you
  19. #159
    Registered User mk3supra's Avatar
    May 2009
    Newfoundland, Canada
    Hey Mudbuddy,
    Awesome info, i was wondering what u can find out about mine. New to me this past May.
    2GTEK19RXW1518623
    Thanks.
  20. #160
    Nov 2008
    Georgia
    I appreciate the report, I never knew it came from Michigan, it didn't have any evidence of salt corrosion
    2004 Pontiac GTO
