Results 1 to 19 of 19
99 Z71 wont start and backfires
This is a discussion on 99 Z71 wont start and backfires within the Technical / Maintenance forums, part of the General Discussion category; Good Afternoon, I have a 1999 Chevy Z71 Pickup with a 5.7L Vortec engine. It used to start right up ...
    Feb 2008
    Hood River, OR
    Good Afternoon,
    I have a 1999 Chevy Z71 Pickup with a 5.7L Vortec engine. It used to start right up but this winter it takes 5 to 7 seconds to start. I went to start it yesterday and it turns over fast like normal but freezes every 7 seconds or so and then proceeds to turn over at normal speeds again. It backfired once and I spoke to my mechanic and he said its the Ignition Module. So I replaced the module and its still doing the same thing....
    Any suggestions?
    Registered User Bowtie00's Avatar
    Oct 2008
    Dallas, TX
    Re: 99 Z71 wont start and backfires
    Check for codes if you find a crankshaft sensor code(p0338, this code will not illuminate the MIL). Replace the Crankshaft Position Sensor. There is a TSB out for this condition about NO START/EXTENDED CRANK/ AND BACKFIRE. Even if you don't find this code I would still replace it, but it can reassure your repair.
    2000 Chevy Silverado 1500 4.3L 5 Speed
    Feb 2008
    Hood River, OR
    Thanks for the replay Bowtie.
    What is the MIL?
    What is a TSB?
    I have no Check Engine Light on currently, or I should say when I parked it last :)
    Oct 2008
    Dallas, TX
    MIL - Malfunction Indicator Lamp, Check Engine Light
    TSB - Technical Service Bulletin, A Report About A Chronic Kind Of Malfunction That Occurs In Some Vehicles
    Edit: That code will not turn on the Check Engine Light
    CENTEXOFFROAD LiftedVictory's Avatar
    Nov 2007
    Waco, TX
    MIL=Malfunction Indicator Lamp(check engine light)
    TSB=Technical Service Bulletin(recalls and such)
    Turn you key on and see if it comes on for a few seconds, then after you start the truck, if it doesn't come on at all, pull the cluster and check the bulb.
    ***Current***
    '97 ecsb z71, 6" RCX, 3" PA BL, 35x12.50x15 procomp, other mods.
    Quote Originally Posted by HawgWyld
    The difference between a 4x4 and a penis is that with a 4x4, you actually go look for bigger holes to put it in.
    USMC
    Nov 2007
    Waco, TX
    Damn beat me to it.
    ***Current***
    USMC
    Feb 2008
    Hood River, OR
    ok, I have replaced the Ignition Control Module and the Crankshaft Position Sensor and it still does the exact same thing.
    It turns over fast and good, then it stops for a moment, then turns over good again. Once in awhile it will backfire. After cranking it for a bit I can smell a little gas fumes.
    Thanks for any help.
    Feb 2008
    Hood River, OR
    So i pulled a sparkplug and tested for spark and I have good spark. I pulled the air intake and can see the butterfly open and close when I pull the throttle cable. So I have spark, air, and fuel, new crank sensor, new ignition control module and no start. What can I check next? Time to tow it to a mechanic?
    I am sinner JWolfe75's Avatar
    Nov 2004
    NJ
    When was the last time you changed the cap and rotor? Pop it off, see if its all corroded
    '05 GMC 2500 HD LLY
    '07 TBSS AWD 3SS
    Quote Originally Posted by BHB View Post
    Ummm...By that, I think that would require sticking my own finger into my "Doug".
    Registered User bwood's Avatar
    Mar 2003
    Denison, Texas
    How many miles? Possible worn dist gear?
    1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
    -Gibson Stainless Cat Back Swept Side
    -255/70 BFG Radial T/A on SS 15's
    Feb 2008
    Hood River, OR
    220000 miles, the short block was replaced 55000 miles ago but im sure they used the old dist.
    Feb 2008
    Hood River, OR
    Took the cap and rotor off and they look normal, I cleaned them up just because I had them off and replaced them. The plug wires are new at the same time I bought the cap and rotor which was around 5 months ago.
    2000 Silverado Dubyagee's Avatar
    Feb 2002
    US
    Did you wash the engine?
    Sounds like crossfire. Change the cap and rotor after verifying the rotor is turning while cranking.
    Feb 2008
    Hood River, OR
    crossfire? you mean inside the cap its arcing across on built up grime?
    Feb 2002
    US
    Tracking inside the cap isn't always easy to see. I would swap the cap and rotor just for giggles and see if that helps.
    Wheeler
    Jun 2004
    Houghton Mi
    Have you checked the fuel pressure?
    2000 Tahoe Z71, 14bFF 6 lug, 241 swap, bumpers, sliders.
    1988 K5, 350/700R/241 locked 10B, welded 12B, 35's, half doors.
  17. #17
    Feb 2008
    Hood River, OR
    UPDATE: I got it started after I removed the Dist Cap and sprayed Brakeclean in it and wiped it out very carefully. It had a small amount of residue in it, like an oily residue but an extremely small amount covering the entire interior of the cap. It still started hard and ran rough for a bit. It seems to be ok but drops to a lower then normal RPM after I rev it, then it returns to normal. I assume I need to look into the Cap seal and a new Cap?
  18. #18
    Feb 2008
    Hood River, OR
    No, I have not checked the fuel pressure. I do not have the tools to do so. I may invest in a gauge very soon as I have no idea if the fuel pump is the original with 220000 miles on it or not.
  19. #19
    Wheeler
    Jun 2004
    Houghton Mi
    Spray WD40 on the outside of the cap and see if that changes it. Kind of sounds like a cracked cap, WD40 will temp seal the crack.
