Results 1 to 5 of 5
05 Silverado Codes P0171 and P0131 and P0300
This is a discussion on 05 Silverado Codes P0171 and P0131 and P0300 within the Technical / Maintenance forums, part of the General Discussion category; Hey guys i am new here so be easy lol I have a 2005 Silverado with 56,000mi, and the 5.3 ...
    Dec 2008
    Maine
    Hey guys i am new here so be easy lol I have a 2005 Silverado with 56,000mi, and the 5.3 L33 in it and Just last night it started to run rough on me it threw 3 codes on me. P0171 and Po131 and P0300 I know you all know the meaning to each break down of the codes... I have read that it could possibly be the fuel pressure regulator??? I can smell fuel up inside the engine compartment would that be a indication of the fuel regulator being bad???? I also smell carbon??? I am new to this so I am just going by what I have read.. Just trying to know whats going on and save some money.. Any info would be greatly appreciated thank you
    Jun 2005
    Texas
    Re: 05 Silverado Codes P0171 and P0131 and P0300
    replace 02 sensor,drivers side front
    May 2004
    Mentor, OH
    Quote Originally Posted by p.hinds
    x2. the p0171 code means that bank 1 (left bank) is running lean. followed by the p0131 which is related to the bank 1 sensor 1 o2 sensor. and p0300 is an engine misfire. just had one last week at work as soon as the bank 2 o2 went into closed loop it dropped to 50mV and stayed there dumping fuel in cylinders 2 4 6 and 8 causing misfires on all cylinders. if it had a bad fuel pressure regulator you wouldnt have any lean codes.
    2007 Summit White Chevy Silverado Z71 Crew Cab, 5.3, Hooker Aerochamber Muffler
    2006 Harley Davidson Nighttrain, Vance & Vines Staggered Short Shots
    Registered User Stevens07's Avatar
    Mar 2003
    Bellefonte, Pa
    P300 can be tripped by a dirty MAF sensor. Clean it and reset the PCM. Just another suggestion.
    Steven
    2007 GMC Sierra SLT Vmax 4.10 gears, Boss MT100 20x8.5 wheels/Cooper Zeon LTZ tires, Extang Bed cover,
    GMC Bedrug, Line of Fire, Denali Grill, GM Performance Intake, Corsa Sport Dual Exhaust, and DiabloSport Predator.
    Dec 2008
    Maine
    Quote Originally Posted by GaryA
    Thanks for the help guys .. I replaced the o2 sensor on the left side just before the Cat cleared codes so far so good.. I will also clean MAF when I have more light... lol Thank you everyone for taking the time and giving me some info..
