Results 1 to 12 of 12
2000 Chevy Coolant Leak
This is a discussion on 2000 Chevy Coolant Leak within the Technical / Maintenance forums, part of the General Discussion category; I have a 2000 Chevy 5.3L and have a coolant leak. I noticed I would have a puddle of Antifreeze ...
    Nov 2008
    sc
    I have a 2000 Chevy 5.3L and have a coolant leak. I noticed I would have a puddle of Antifreeze on the floor in the morning. Last night I put the truck up on the ramps so I could see were it was leaking. This morning I can see that it is leaking from the front of the block but I cant see were it is coming from. The water pump looks dry from what I can see. What is the common places for it to leak on this truck?
    2003 Chevy 2500HD Single Cab 6.0L 291k
    2000 Chevy 1500 Extended Cab 5.3L 237k
    1955 Chevy 3800 1 Ton Flatbed
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Re: 2000 Chevy Coolant Leak
    Quote Originally Posted by cedarstump
    water pump or water pump gaskets
    2000 Silverado 6.0 4L80E 2wd
    Jan 2007
    Clovis, Ca
    I agree with Dave, mine was leaking about a year ago it was the gaskets, so I put a new pump on at the same time.
    66 Impala 396
    2000-1500 Excab LT stepside 2wd
    2006 T.Blazer LS 4x4
    Sep 2007
    somewhere
    My 99 Sub had intake manifold gasket problem. The coolant would pool right above the water pump after the motor was run and shut down. So, I would not have a puddle on the ground, mainly because it would burn off due to the heat of the engine. But what did remain was pooled above the water pump. After the intake gaskets were replaced I had no more problems.
    I hope in your case it is just the water pump gasket, a lot cheaper fix.
    Nov 2008
    sc
    How can you tell if it is leaking from the Intake?
    Registered User Bowtie00's Avatar
    Oct 2008
    Dallas, TX
    On a NBS,NNBS Chevy Truck the intake has no coolant running through it. Its just air.
    EDIT: JUST THE V8s
    MY V6 IS LEAKING COOLANT FROM THE INTAKE GASKETS
    2000 Chevy Silverado 1500 4.3L 5 Speed
    Dec 2008
    Anderson, IN
    there is a square drive plug on the block or head (can't remember) on the front driver's side of the engine that i've seen several leak out of. tighten it up, and it goes away.
    88 ECLB "The War Wagon"
    96 Camaro Z28, LT1, Auto, Intake, Exhaust, failing OptiSpark mod.
    Aug 2003
    Potsdam, NY
    mine was the water pump gaskets and I've seen many other 5.3's and 6.0s that did the same.
    01 Z71 ECSB, 3" PA, 305/70-16 on AR 10" Atlas SOLD 9/28/09
    2010 Ford F-250 Super Duty Lariat RIP 1/13/10 7554 miles
    2010 Ford F-350 Super Duty Diesel Lariat
    04 Ford Mustang SVT Cobra
    Nov 2008
    sc
    What is the best brand of water pump? Would a duralast from autozone be OK? Looks like they are around $130.
    Supporting Member
    Dec 2008
    Crack Alley
    You can get the OEM pump from gmpartsdirect.com for $150.
    Meatstick
    Apr 2007
    Illinois
    Quote Originally Posted by Meatstick
    Meatstick
    thats the way I would go.....You can also check out RockAuto.com
    2000 Z71 Extended Cab
    182,000 Maroon and Silver
    Nov 2008
    sc
    Thanks for the help. Rock Auto has the water pump for $79 + shipping
