Results 1 to 8 of 8
How to remove fan from water pump?
This is a discussion on How to remove fan from water pump? within the Technical / Maintenance forums, part of the General Discussion category; I am changing the water pump on my 2000 5.3L and having trouble with the water pump pulley spinning when ...
    Nov 2008
    sc
    I am changing the water pump on my 2000 5.3L and having trouble with the water pump pulley spinning when trying to remove the fan nut. Does anyone have any tricks to remove the fan? Thanks in advance.
    2003 Chevy 2500HD Single Cab 6.0L 291k
    2000 Chevy 1500 Extended Cab 5.3L 237k
    1955 Chevy 3800 1 Ton Flatbed
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Re: How to remove fan from water pump?
    belt still on?
    2000 Silverado 6.0 4L80E 2wd
    Registered User gmsuv's Avatar
    Aug 2006
    Michigan
    Just take a rubber hammer and strike the fan blade nut counter clockwise with a wrench on the nut facing the engine. It'll spin off fan blade and nut together.
    Nov 2008
    sc
    Yes, the belt is still on.
    FSC Midwest Chapter! Nyle's Avatar
    Mar 2008
    Decatur, Illinois
    use an air chisel, i gave up on doing them with hand tools years ago
    Formerly Grey89
    97 Chevy K3500 CCLB SRW 6.5L, 4" exhaust, 305's, 20% tint, block/cranked-Sold
    97 Chevy K1500 Suburban-Sold
    Quote Originally Posted by MSF
    DD'n an OBS is great... If you don't have to go anywhere, or you can afford a $hit ton of gas.
    Aug 2006
    Michigan
    Take the belt off and put a large cresent wrench on the nut and give it a big wack
    Nov 2008
    sc
    Got it. Put vice grips over the belt and pulley then tapped the cresent wrench with hammer and it came off. Thanks for everyone's help. This site is great!
    Registered User figment3's Avatar
    Nov 2008
    mars
    last itme i did this to change out water pump, remove whole assembly fan adn pump as one unit, once out you can open the back of the pump and jamb the viens inside in the vise and then its east to remove,
