How much are you lookin' to spend on a complete dizzy? Dont know about that one you listed but www.performancedistributors.com has some set-ups that are good quality and are billet.
This is a discussion on 5.7L vortec distributor question within the Technical / Maintenance forums, part of the General Discussion category; I found this on ebay , i am changing intake gaskets soon and distributor gear but this whole distributor isnt ...
I found this on ebay , i am changing intake gaskets soon and distributor gear but this whole distributor isnt much more , anyone bought one of these off ebay before? It says its aluminum housing instead of plastic , i dont have the money for a new accel . My truck is pretty much stock , What do you guys think should i get it ?
http://cgi.ebay.com/ebaymotors/ws/eB...m=270325748871
'98 ECSB, Edel Headers, Magnaflow Cats/CatBack
K&N, Pully, Ign.Kit, D/S Rotors, SS Lines, BB 89 Tune
Built 4L60E w/ Vigilante 2800 Stall
http://photobucket.com/R3215T3R/ (Toyvrolet Drag Truck/S-10 Drag Truck)Pics.
I emailed the person selling that same distributor and asked about it. He said that the cap, rotor, and the internal sensor are all aftermarket and that the gear is stronger than the original ones. Take that for what its worth. I'm thinking about getting one for my 98 454. Let me know if you get one and how you like it.Originally Posted by jdnz28
There is also a billet aluminum dist. on ebay that uses GM parts for the sensor and gears. Not sure about the cap and rotor though. Its $250.
Wayne
98 ext-cab Z-71 5.7L/4L60E/10 bolt/3.73 locking diff
Borla duel rear exit exhaust, HD bilstein shocks LT265/75R16 Michelin LTX A/T tires
98 reg cab long bed K3500 4x4 7.4L/4L80E/14 bolt FF/4.10 locking diff. Flowmaster Cat-back, LT245/75/16 Michelin LTX M/S tires.
I would suggest replacing the dizzy gear if it shows wear but I wouldn't spend the money on a new dizzy if the current one isn't broken. You don't have to take the intake off to replace it. In fact, it comes out before taking the intake off.
'96 Tahoe...5.7 Vortec...4wd...~193,000...Stock
Along with the gear, another problem with the OEM distributor is that the main housing is made of plastic. The distributor cap screw hole gets stripped with no easy way to repair it.
If you buy the new distributor, let us know how it works out.
Also, make sure you have a way to set the "CAM retard" for the distributor after it is installed.
Originally Posted by masintenn
Yea i have to replace my intake gaskets so i figured while i got the dizzy out i would change the gear , i wanted to see if anyone has tried this Distributor off ebay cause it seemed really cheap. If i buy it ill let you guys know how it works.
Originally Posted by NoEcm
Thanks NoEcm, yea im hoping to get it pretty close when i install it to get a scanner on it. You have any idea rough estimate how much they will charge me for just setting the Cam retard ?
i bought that dizzy from EBAY, no problems, works great
Originally Posted by james_8997
Thats great to hear i was going to order the gear from summit with some other things for 49 bucks but is seen this on ebay and thought i might give it a shot cause it comes with everything
Sorry, no idea but the labor should not be over 1/2 hour (I'm guessing). You might want to make a phone call and get an estimate and post your findings here.Originally Posted by jdnz28
no go on tha gear, i tried that and tha one they said would fit, didnt, i just got tha new dizzy and it worked out great
Cool yea ill do that
thanks for the heads up on that gear, yea im leaning towards that distributor maybe in the next week or so got to get some funds together
I've been running that dizzy for a while now. No complaints whatsoever.
'97 GMC ECSB GMT400
Andrew
I think I paid ~$40 for just the gear a couple of years ago.
I'm running one of those dizzy's from Alex (ignition DK).
No issues here. Sure beats the plastic OEM crap!
Howard
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
DUCT TAPE.
98 K1500 Suburban, 4L80E, Whipple SC, Marine Intake, Hydroboost, LS1 0411 PCM.
