Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
How to install dual alternators - NO fabrication required!!!
This is a discussion on How to install dual alternators - NO fabrication required!!! within the Technical / Maintenance forums, part of the General Discussion category; This is how my truck is wired for the dual alternators, including wire gauge sizes. It should be extremely easy ...
  1. #21
    1986 ATC250R FTW Nick_R_23's Avatar
    Jul 2008
    Alaska
    Re: How to install dual alternators - NO fabrication required!!!
    This is how my truck is wired for the dual alternators, including wire gauge sizes. It should be extremely easy to read, RED wires are positive, BLACK wires are negative/ground. This is not the only way to do it, but it should be a good start if wiring is not your strong point. Keep in mind that the wire gauges sizes I have shown on here are only what I am using, for most applications stock wire sizes are fine.
    1988 Chevy Silverado 5.9L Cummins : 1968 Ford Mustang Pro-Touring
  2. #22
    Supporting Member 1997chevydriver's Avatar
    Jul 2010
    Mora, Minnesota
    im assuming on off switch is just incase of a dead batt???
    Current Ride
    2004 Chevrolet Silverado 2500HD 4x4 6.0L
    Past Rides
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    1994 K1500 ECSB Z71 5.7L 350
    1992 C1500 ECLB 5.7L
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
  3. #23
    Jul 2008
    Alaska
    Quote Originally Posted by 1994chevydriver View Post
    Yes. If the main battery or alternator ever failed, I can turn the switch on and run off the secondary battery and alternator.
  4. #24
    Nov 2011
    United States
    So i think i did something wrong i think i took off the wrong screw im leaking antifreeze...what bolt did i take off wrong? its towards the bottom of where the old bracket from the ac compressor used to be ....any idea?
  5. #25
    meh
    Aug 2011
    Columbus OH
    It sounds like you took a water pump bolt out. I cant think off hand what bolts hold the bracket but if you just put it back it should be fine. Just check for leaks later.
  6. #26
    Jan 2012
    Wisconsin
    that is super sweet. definitely helpful
  7. #27
    Registered User The Confederate's Avatar
    Sep 2010
    Lebanon, Tennessee
    Not sure of your attitude of mixing make parts, but you could use an older Ford starter solenoid (fender mount type) in place of your on/off switch. Just spice into the ignition switch wire from the Chevy solenoid and run a wire to the "S" terminal of the Ford solenoid. Wah-la! You can now use both batteries to crank the starter, while isolating the circuits otherwise! Use identical batteries of course with this set up, and using 2 batteries, there are more AMPs available, so a dead battery shouldn't happen unless you left something on.....
  8. #28
    May 2012
    Ionia(I-OWN-YA),MI
    Bump for good info. Am I correct in assuming this will work on my '94 TBI 350 w AC? I'm more than willing to eliminate it since I'm planning for onboard air as well.
  9. #29
    Jul 2008
    Alaska
    Quote Originally Posted by HawgEnvy View Post
    Sorry for the late reply. Yes, this will work on your '94 as long as you are fine with ditching your A/C pump.
    To clarify, this mod will work on all 86-95 TBI engines, or any regular SBC with TBI accessory brackets installed. I may be working on a 96+ Vortec setup soon, so keep your eyes peeled.
  10. #30
    AQUATIC GOAT FARMER
    Mar 2008
    Livingston, TX
    So I hate to resurrect old posts but I did some work on this project to have two alternators AND cold AC. I'm going to run mine in parallel.
    https://plus.google.com/u/0/10170483...ts/DZHED9K8QJK
    Let me know what you guys think.
  11. #31
    Feb 2006
    Tempe, AZ
    Quote Originally Posted by Nick_R_23 View Post
    I am definately hoping for 96+ dual alt design.
  12. #32
    Jul 2008
    Alaska
    Quote Originally Posted by Smoove View Post
    Spoiler; the 96+ Vortec dual setup is actually pretty easy, but still requires deleting the A/C. I started mocking up the setup, but I had to get rid of my mock up engine, so I don't have all the specifics like belt part numbers or lengths, etc. Basically, you use your entire Vortec setup minus the aluminum bracket for the A/C pump. Delete your A/C pump, install a power steering-alternator bracket from the 88-95 TBI trucks, and bolt on another alternator. Hopefully I can get back on this project sometime and have all the specifics posted here for you guys, but that should get you 96+ guys started in the meantime. Due to some supposed changes in the power steering pumps in some years, changing to a pre-96 pump may be required, but highly unlikely, I haven't been able to research this yet.
  13. #33
    Mar 2014
    ohio
    Thumbs up Re: How to install dual alternators - NO fabrication required!!!
    first off I wanna say this was very helpful. I am putting a second alt on my 6.2 diesel cause of amber light bar, work lights, strobes ect. mounting was easy ordered a driver side bracket from ebay came off a military truck. But when it came to the wiring I got confused cause I want them to be separate but if need be to have them run together. so my main question is in the diagram you show a on off switch between the 2 batts. what kind of switch did you use to handle the power? again this was very helpful
  14. #34
    Registered User Bigbodylexus's Avatar
    Apr 2013
    Wichita, KS
    I am still looking for some help. I have a 1990 Chevy Suburban (5.7L V8) and I am wanting a dual alternator setup. I do NOT want to lose my A/C, does anyone know of a place that sells/makes them?
  15. #35
    Jul 2008
    Alaska
    Bump for 2016! Guess it's been a while since I've been here.
    Quote Originally Posted by farmer43567 View Post
    Typically any high-amp style switch will work, as long as it's rated for the load your plan to pull through it. Most any auto parts store should stock a battery cutoff switch, they're very commonly used in most racing applications.
