Results 1 to 4 of 4
what do these codes stand for...
This is a discussion on what do these codes stand for... within the Technical / Maintenance forums, part of the General Discussion category; I was messing around to day with the hyper tech programmer that I have and I got these three codes, ...
    Sep 2009
    texas
    I was messing around to day with the hyper tech programmer that I have and I got these three codes, C0040, B1035, B1055, could anyone help me out and tell me what they stand for.
    May 2004
    florence alabama
    Re: what do these codes stand for...
    C0040 - Right Front Wheel Speed Circuit Malfunction
    B1035 - Discr. Sensor Closed or Short to GND
    B1055 - Audio Output 4 Circuit (Radio)
    " Patton said it best " Wars are not won by dying for your country, wars are won by making the other poor son of a b#### die for his country! "
    Sep 2009
    texas
    thanks for your help, can you explain to me how i can fix them
    May 2004
    florence alabama
    Those would require a Tech-2 to sort out. The B codes are from the BCM Body Control Module and the C code is chassis.
    The C0040 could be a bad connection on the right front wheel speed sensor. Check the connections. Look behind the hub for wires and follow them and check the plugs. It could be a number of things. A bad circuit is a pain to trace.
