Results 1 to 8 of 8
98 Z71 Overheated
This is a discussion on 98 Z71 Overheated within the Technical / Maintenance forums, part of the General Discussion category; My 1998 Z71 overheated and now has a miss and the radiator is getting back pressure. I believe this is ...
    Oct 2009
    Texas
    98 Z71 Overheated
    My 1998 Z71 overheated and now has a miss and the radiator is getting back pressure. I believe this is a blown head gasket, cracked head or warped head. I hear that the Vortec heads are bad to warp or crack when overheated. what do I do next? What other problems am I possibly facing?
    Registered User daved931's Avatar
    Apr 2008
    Bangor, ME
    Re: 98 Z71 Overheated
    I would think the iron Vortec heads are fairly resistant to warping, but it all depends upon how hot you got things.
    Maybe start with a compression test on each cylinder?
    1999 2 Door Tahoe 4x4 w/ 14 Bolt SF & TruTrac. All kinds of upgrades, SOLD 1/2012
    2008 Silverado 1500 Z71, leveling kit, exhaust, SOLD 9/2014
    2014 Silverado 1500 Z71, stock for now
    0_o o_0 0_o o_0 98GreenMachine's Avatar
    Aug 2005
    St. Paul, MN
    What do you mean by 'the radiator is getting back pressure'?
    98 K1500 Z71 - 204k | L31 | 60E | 3.73's | 3" BL | 33x12.5x15 Dick Cepek F-C II's | Dynomax Ultra Flo X DI/DO | 14 MPG
    Registered User jake760's Avatar
    May 2009
    USA
    Sounds like a blown head gasket. X2 on checking compression across cylinders. What did you do to make it overheat?
    Oct 2009
    Texas
    My son was driving it, who knows. I think the water pump has leaking weep hole and he has not checked the water apparantly.
    Oct 2009
    Texas
    When you turn the engine over the radiator will build up pressure. I had a 91 350 overheat by the other son and it did the same thing, the heads were warped on it.
    Apr 2008
    Bangor, ME
    That's just compression leaking from the combustion chamber into the cooling system though, right?
    Oct 2009
    Texas
    Yes I am assuming if the head is cracked, warped, or the gasket is blown the pressure build up in the radiator is from the compression of the motor cylinder or cylinders that is leaking
