Results 1 to 9 of 9
2000 z71 rear end noise
This is a discussion on 2000 z71 rear end noise within the Technical / Maintenance forums, part of the General Discussion category; when i put my truck in gear and give it gas i hear a sound that almost sounds like a ...
    Registered User 2000gmcz71's Avatar
    Aug 2009
    Mississippi
    when i put my truck in gear and give it gas i hear a sound that almost sounds like a poooooop real light sound but loud enough to hear and it feels like i have a little slack back there. i can give it just a little gas, just enough to get it rollin and it wont do it only when i just hit the gas and go has anyone else ever had this problem..
    2000 Z71
    Leveling Kit
    305/70/r16 hankook M/T
    Dual Exhaust
    4in Rear Blocks
    :fsc:
    Jul 2009
    Hot Springs,AR
    Re: 2000 z71 rear end noise
    Sounds like a U-joint going south on ya.
    Aug 2009
    Mississippi
    wouth that make it feel like there was slack in the rear end
    2000 Z71
    Leveling Kit
    Dual Exhaust
    4in Rear Blocks
    :fsc:
    potato gon' potate SlvrdoHDmax's Avatar
    Aug 2008
    Jackson, Missouri
    either that or the slip yoke
    Aug 2008
    Jackson, Missouri
    Quote Originally Posted by 2000gmcz71 View Post
    yes
    G-FORCE FinalBreath's Avatar
    Sep 2007
    Milwaukee, WI
    Spider gears going bad?
    88 K1500 5.7 220K SOLD
    95 K2500 5.7 336k SOLD
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    Aug 2009
    Mississippi
    can you replace a slip yoke and how can you tell if its goin bad... also why do u say spyder gears
    2000 Z71
    Leveling Kit
    Dual Exhaust
    4in Rear Blocks
    :fsc:
    Nov 2009
    Knoxville
    Sounds like U-join to me as well. I don't see it being the spider gears. I'd go with the U-join they are pretty cheap.
    Aug 2008
    Jackson, Missouri
    The slip yoke doesnt go bad, just makes noise. You can take the driveshaft off and pack it full of grease to cure the problem for a while. But most likely u joints. Possibly spider gears considering your tires.
