Results 1 to 11 of 11
2005 silverado Service Airbag Light stays on!!!!
This is a discussion on 2005 silverado Service Airbag Light stays on!!!! within the Technical / Maintenance forums, part of the General Discussion category; I have a 05 silverado and the other day i started it up and as normal the airbag light flashes ...
    Jul 2005
    Beckley, WV
    I have a 05 silverado and the other day i started it up and as normal the airbag light flashes then goes off. Then bout 5 secs later the comes back on and a get a Service Airbag message on the info center???? the airbag lights stays on the whole time after that... I still have stock radio, pcm and i have not must with anything on the truck elec. !!!
    Thanks for any Help
    Brandon
    05 Reg.Cab Stepside bed
    Cowl Hood
    17X9 Procomp
    285/70/17 BFG KO
    Volant Cold Air intake
    Black Bear Tuned...
    SLP LoudmouthI Dumped..
    Tinted windows
    Superliner Sprayed in Bed
    and More....
    EFI Live
    Jan 2008
    Wolfpack Country
    Re: 2005 silverado Service Airbag Light stays on!!!!
    i would start by servicing the airbags. good starting point.
    -Alex
    Thanks to:
    Dustin @ Diesel Addiction
    Rick @ Pro Fab Performance
    John @ Kennedy Diesel
    Jul 2005
    Beckley, WV
    everybody loves a smart ass i guess maybe where the problem could be or anybody had the same problem and what they had to do??????
    and Alex you are cool my man
    Cowl Hood
    17X9 Procomp
    285/70/17 BFG KO
    Black Bear Tuned...
    Tinted windows
    and More....
    EFI Live
    Jan 2008
    Wolfpack Country
    how do you know my name?
    lol check the fuses i guess. i would search and help you but im attempting to do a paper right now. damn fsc keeps destracting me....
    -Alex
    Thanks to:
    Registered User ohio4whlr's Avatar
    Oct 2009
    ohio
    there could be any number of problems. could be sensors or clock spring,air bag. most generic scanners can't do air bags, so go to a reputable shop to get the codes. i highly suggest having a pro do the repairs if you do something wrong it is a possability to blow the air bags.
    Registered User ntimidator_3's Avatar
    May 2008
    Look out your window..............
    you may want to do a search. I think there was a service bullitin on air bag systems
    by the way, where in Oh are you
    2004 Silverado 2500HD 4X4, reg cab Long bed. 253000 miles
    Thanks for the sig 454SS
    Jul 2005
    Beckley, WV
    thanks i am in beckley wv
    Cowl Hood
    17X9 Procomp
    285/70/17 BFG KO
    Black Bear Tuned...
    Tinted windows
    and More....
    Registered User bobfig's Avatar
    Jun 2008
    Houston, Texas
    Quote Originally Posted by 01SilvyZ71 View Post
    look in your sig above your trucks XD
    05 Silverado 1500 CCSB - 799 heads milled .030", Airaid MIT, Black Bear Tune, and Magnaflow 12259, Tru-Cool 40k, Vette Servo
    97 c1500 RCSB 4.3L 3" Spintech Pro Street dumped, vette servo, and LS1 fans - SOLD
    Sep 2007
    Cape Cod, MA
    My airbag light came on once a while back. I traced it to the new HID kit I installed. The driver side ballast was temporarily mounted with dual sided tape and over time it moved a bit and came into contact with the PCM cover. The ballast was sending out enough interference to mess with the PCM. My airbag light would stay on and my AC would turn on for no reason. I found a permanent mounting spot for that ballast far enough away from the PCM and haven't had an issues since.
    Not sure if that short story there will help you out but if by chance you have an HID kit installed or have changed anything around that PCM area it would be worth looking into as a possbile source of the new problem.
    EFI Live
    Jan 2008
    Wolfpack Country
    Quote Originally Posted by bobfig View Post
    :sarcasm:
    lol
    -Alex
    Thanks to:
    Oct 2009
    ohio
    Quote Originally Posted by ntimidator_3 View Post
    central ohio
