just follow the tan black wire from the distributor.
This is a discussion on 1990 GMC suburban 350 TBI timing within the Technical / Maintenance forums, part of the General Discussion category; I need to set the timing on this engine,(totally stock snow plow truck). a mechanic told me to set it ...
I need to set the timing on this engine,(totally stock snow plow truck). a mechanic told me to set it at 0 degrees after disconnecting a tan wire with a black stripe near the distributor or back of the driver side valve cover to disable the advance signal from the advance module, I cannot locate tan wire with a male/female disconnect, the only wire back there with a disconnect is a purple wire,that is way downbehind cover and I can only touch with the tip of my finger,any help out there locating the correct wire???, thanks.
Matching Ninja 500r
May be behind the black plastic cover on the passenger side firewall or like mine and behind the glovebox and under the dash.
It's under a big black plastic piece on the firewall that holds all the fusible links.
1993 C1500, 5.0L, 372,000mi
2006 GTO, 22,000mi
