Page 1 of 2 12 LastLast
Results 1 to 20 of 26
94 5.7L TBI dies at idle or when coming to a stop
This is a discussion on 94 5.7L TBI dies at idle or when coming to a stop within the Technical / Maintenance forums, part of the General Discussion category; hey i have a 94 z71 5.7L that will die at idle or after i let off the fuel peddal ...
    94 silverado
    Dec 2009
    on
    hey i have a 94 z71 5.7L that will die at idle or after i let off the fuel peddal while coming to a stop or corner but it only does it sometimes after it dies it takes a whole lot of cranking with my foot to the floor to get it started again and have to keep the rpm's up to keep it running then the next corner or stop i come to it dies again unless i put it in nuetral and keep the rpm's off idle
    the check engine light is on it is code 43 knock sensor circuit not thinking that that would make it stall but just before it does stall the check engine light goes off then all dash warning lights come on then engine light comes on again
    what i've changed
    fuel pump
    fuel filter
    iac
    coil
    ecm
    anybody have any idea's???? please !!!!!! help!!!
    this thing is really starting to piss me off lol
    Oct 2007
    TN
    Re: 94 5.7L TBI dies at idle or when coming to a stop
    The knock sensor may be doing it. I had a 91 Corsica, different fuel system, but it went bad. Driving or at idle it would surge real bad. changed the sensor ran great.
    Don't remeber if you can test the knock sensor or not. It should be cheap if you want to try to replace it. Not hard to do.
    How does your air filter look? When was the last time the throttle body was rebuilt? Kit cost about 30 or 40 bucks. It also comes with a FPR which could be part of your problem. Good time to clean your TBI too.
    I would also check your timing.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Jan 2007
    Nebraska
    egr
    94 silverado
    Dec 2009
    on
    egr is new as well
    when it runs it runs great no surging nothing then when it wants to it dies i don't think the tb has ever been done i've only had it for five years
    HAULIN A$$,AND SUCKIN GAS 350CHEVYROB's Avatar
    Nov 2009
    Kalamazoo.Michigan
    i was thinking the temp sensor on top of the intake manifold.
    95 GMC Yukon 1500 4X4
    94 silverado
    Dec 2009
    on
    why would u say that ??
    94 silverado z71 6" lift 35" tires 4.56 gear ratio
    02 silverado stock
    81 serria stock
    Registered User LeoP's Avatar
    Oct 2009
    Southern Md
    IAC valve, may be dirty or slow to react, clean it first but you may wind up replacing it. post back with the results please.
    94 silverado
    Dec 2009
    on
    iac has been replaced throttle body removed and cleaned out iac port still acting up ran jumper wire from battery to distribution block i think the fuesable link is acting up in the middle of testing get back to you on that one
    02 silverado stock
    81 serria stock
    94 silverado
    Dec 2009
    on
    and of course now it won't die even without the jumper on it so i don't know if that was it or not
    02 silverado stock
    81 serria stock
    94 silverado
    Dec 2009
    on
    ok so that wasn't it the iac i replaced was from a scrap yard and it did run alot better after i replaced it for about two days then it started acting up again should prolly try a new one i guess
    02 silverado stock
    81 serria stock
    May 2009
    Michigan
    have the timing checked.. make sure that the idle advance wire (can't remember if that's the name or not) is disconnected.. check your distributer for moister/play.. you shouldn't be able to turn it because that bolt should be tight enuff to hold it..
    do you have lifters ticking or other noise under the valve covers? the knock sensor senses spark knock.. it can be very sensitive and retard the timing for things like that.. could also be bad gas.. have you eaten a burrito lately?? or more appropriately taken it to a diff gas station? or the cheapest gas station around?
    edit: forgot to add - check the wire that connects to the knock sensor.. mine is located almost at the bottom of the engine..it's a 1 pin connector in mine... behind the oil filter.. "ish" i had a bad connector and they are notoriously so.. if you do change the knock sensor change that connector as well
    94 silverado
    Dec 2009
    on
    i checked the timing it's good it has been doing this since the end of last winter so i have been to many different gas stations so bad gas is out the knock sensor i unhooked completely and it did;nt make a differens
    i really think it's the iac i did change it and it did run good for a couple days but it was from a junk yard i unscrewed the iac a bit from the throttle body just until it started to rev up a bit and it hasn't died since well until it screwed it self back in then it did but a little adjustment and a way i went
    02 silverado stock
    81 serria stock
    bikes cars trucks women vic_V8's Avatar
    Jan 2004
    Dixon IL
    Quote Originally Posted by 350CHEVYROB View Post
    YES! exactly what I was going to say, buddy had the same problem, I replaced that and it was fixed, when it fails the truck thinks its VERY cold out and over compensates for it.
    '84 K30, 7" lift, Converting to International Diesel HP 60/14 combo
    '88 GMC Suburban V2500 5" lift 60/14 with 4.10s 5.3 LS swap TH400/NP208
    '94 GMC Suburban K1500 350/4L60e with updated heads, mild upgrades
    '77 Ford F250 High Boy 400/C6/Divored 205 44/60
    Veteran of Afghanistan (Army SSG)
    94 silverado
    Dec 2009
    on
    ok up date changed knock sensor which got rid of my check engine code but still dies just changed the temp sensor but haven't got to try it yet sry it took so long for an update just got the net again
    02 silverado stock
    81 serria stock
    Registered User DragonZ71's Avatar
    Sep 2006
    NorCal
    Just a suggestion, recheck your ignition coil and also check to see if the plug gaps are in spec and to see if there's any carbon fouling on them. I had a similar problem on one of my vehicles and found out that there was too much gap on the plugs. Regapped the plugs to spec and problem gone.
    94 silverado
    Dec 2009
    on
    took it for a drive all seems awsome so far i love u guys lol
    02 silverado stock
    81 serria stock
  17. #17
    Dec 2009
    IN
    So replacing the intake temp sensor fixed the problem?
  18. #18
    94 silverado
    Dec 2009
    on
    well its called the coolant sensor still but its the one that tells the ecm how cold it is. its right beside the thermostat housing and yait hasn't died since
    02 silverado stock
    81 serria stock
  19. #19
    Dec 2010
    El Paso, TX
    I know I am really late on this one, But wasn't the ECM showing any codes? I figured that if the ECT was at fault it should have registered a DTC 14 or equivalent. But the bottom line I have the same problem and ran across this forum. It's so funny, but with the ECM you should know right away what sensor is causing the problem. The Problem I have, a truck I'm working has been so abused that I'm not sure that the ECM is still my friend. I just started changing sensors just to show the ECM that I was a friend. But I will admit that I stopped short on the ECT. But what the hell I'll put that one on the list as well and see if I can get Harmony back to this Rig. If it works then I want to thank the ones who came before me who was nice enough to document their history of the same problem that I'm having now!
  20. #20
    94 silverado
    Dec 2009
    on
    Aaahandy sry I haven't updated this in a long time it was true that my truck Disnt die for like three days but it did die. And it finally wouldn't restart at all did some tests and found no spark and no fuel coming from the tbi changed the ignition control module under the distributer and a way we went no problems since
    Once again sry for the delay in this post
    Good luck hope this fixes urs too
    02 silverado stock
    81 serria stock
