Results 1 to 11 of 11
4.3 to 5.7 swap engine mount question.
This is a discussion on 4.3 to 5.7 swap engine mount question. within the Technical / Maintenance forums, part of the General Discussion category; Alright guys, I'm currently halfway through my 350 swap and I'm having trouble with the old v-6 mounts. The truck ...
    Registered User enederhoff's Avatar
    Dec 2008
    Fulton, IL
    Alright guys, I'm currently halfway through my 350 swap and I'm having trouble with the old v-6 mounts. The truck is an '89 c1500. I cannot seem to get the old mounts off due to the fact that I cant find a way to get the bolts out. There are nuts on the backside, but it is almost impossible to get a wrench or socket on them. It almost seems that I'll have to compress the coil springs and unbolt the lower A-arm. There has to be an easier way to do this. Any input is greatly appreciated!
    1989 Chevy 1500 4.3 V6. 350 swap in progress.
    DSOC #67 b16a3 del Sol.
    Dec 2008
    Fulton, IL
    Re: 4.3 to 5.7 swap engine mount question.
    ttt guys, hoping for a little help as I plan on working on this tomorrow!
    Apr 2003
    Ft.Lauderdale, Fl.
    Been there. The answer is:....Leave the V-6 mounts(frame mounts) where they are. Use them as they are. I fabricated engine block mounts, that bolt perfectly to the V-6 frame mounts. They consist of simple flat steel plates that bolt to the block, with two steel ears that drop down, that you can slide a bolt through. And they don't have to be made from thick material either. Mine are fabbed from approximately 3/16" steel plate. Very simple to make & paint. Hope this helps.
    Apr 2003
    Ft.Lauderdale, Fl.
    Oops. Just realized you might be installing a regular Generation 2 350 motor. My bad. What I suggested applies to Generation 3 or 4 LS series engines, into an OBS Chevy truck, that had a V-6 in it originally.
    Dec 2008
    Fulton, IL
    Thanks for the response, but yes the motor im using is a second gen 350.
    Now I know quite a few guys on this site have done this swap but there is no additional info to be found on removing the old mounts. Anyone else got anything?
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    extension, and a swivel socket to hold the nuts
    a\or, cut the old bolts, and use new bolts/nut, will still need a swivel socket and extension, but its easier to do, if the bolts come from the bottom
    2000 Silverado 6.0 4L80E 2wd
    Dec 2008
    Fulton, IL
    When I go to put the socket/swivel/extension it seems I can only get to one or two of the nuts. I'll hafta give it another go..
    Dec 2008
    Fulton, IL
    Also, is the starter from the 4.3 the same as the one on the 5.7? It bolted up but are the teeth the same as well? Figured I should try and make sure before going to start it and have the wrong starter..
    Oct 2009
    nc
    Is your truck 5 speed or auto? I have one thought about putting a v-8 in and wonder if the flywheel is the same for v-6 and v-8.
    Sep 2007
    SE Michigan
    they call for the same auto trans flexplate, yet different manual trans flywheels
    starter will work for both
    I would honestly use the flywheel, but that is me
    Dec 2008
    Fulton, IL
    My truck is an auto, figured they were the same, but had to make sure.
