Results 1 to 5 of 5
99 Sierra heater problems....
This is a discussion on 99 Sierra heater problems.... within the Technical / Maintenance forums, part of the General Discussion category; So I have a NBS 99 Sierra. The heater blower motor will only run on 5(high). I figured it was ...
    The One Smokedawg's Avatar
    Nov 2002
    Indiana
    99 Sierra heater fan switch problems....
    So I have a NBS 99 Sierra. The heater blower motor will only run on 5(high). I figured it was the heater fan switch so I went and bought a new heater switch/panel. Exact same problem. Is there a relay I should check? Any suggestions?
    Thanks!
    Derek
    2008 GMC Sierra - 5.3L, 6" lift, 35" Nittos, K&N CAI, Rhino Liner
    1990 Mustang GT- 347 Stroker, Nitrous, full suspension and lots more
    1995 Chevy S-10 - 406 SBC, 400 Turbo, Dual tunnel ram, Dart 215 Pro1 heads, Nitrous, full tub, 9in rearend
    Aug 2009
    va
    Re: 99 Sierra heater problems....
    resistor gone bad.
    Nov 2002
    Indiana
    Just picked up a new resistor..Will put it in shortly..Thanks!
    Nov 2002
    Indiana
    Heater is working great now..Thanks!
    Aug 2009
    va
    Great,glad to help.
