Removed your wipers? Interesting and rather unique, it seems. Round here we need those for inspection and of course rain, snow and mud etc
This is a discussion on What did you do to your FSC today? within the Technical / Maintenance forums, part of the General Discussion category; put new energy suspension upper control arm bushings on the 97 Z71 and putting idler, Pittman arms and new torsion ...
put new energy suspension upper control arm bushings on the 97 Z71 and putting idler, Pittman arms and new torsion bar bolts (because one broke) on tomorrow. and changed oil and did a few mods on the Z28
97 ECSB 6.5 BDS suspension 3 body lift 20x10 KMC D-backs 40x13.50x20 Mickey Thompson ATZs Vortec 5.7: Long-tubes Super44, CAI, MSD 6A, E-Fan, 180 stat, TB spacer, polished MAF & TB, 5:13s Shift Kit and Black Bear Tune
04.5 Silverado 2500HD Duramax
03 Sierra ecsb 4x4 4.8l 3.73 4l60e
I went outside and looked at it and remembered how high gas prices are and went back inside..
Drove it to the doc's office and back home.
__________________________
Jack in Michigan
1992 Chevy K1500 Silverado Ext. Cab Sportside
1997 Chevy Camaro Z/28 Convertible
1965 Chevy Chevelle 300 DeLuxe 4-Door
Wife's truck:
2005 Silverado Crew Cab Z/71
Drove it to town to get U-joints for it.
Broke 1 bolt out of 4 on the rear axel yoke
Couldn't get the rear Ujoint out of the driveshaft so I stole the driveshaft from my 94 and put new Ujoints in that one.
Removed yoke put it in a vice and drilled out the broken bolt, tapped/cleaned threads in all 4 holes.
Installed DS and remembered that in order to grease the rear Ujoint you have to disconnect ujoint from rear axel
Took for a test drive.
...............I need a beer![]()
<------Thanks to Mean Green
1994 K1500 ECSB Z71 5.7L 350
1997 K1500 ECSB Z71 5.7L 350 Vortec
Hooked my EGR back up, trying to improve my hwy MPG
'95 GMC Z71|L05|GT4|Yukon 17s|Belltech|Purple Keys|FastChip|Hedman|Borla Pro|XtremeFI|Goodmark|Kenwood|Memphis|Ultimate TBI Mods|E Fan|
Much More to Come...
5200 lbs. at 12.4/15.9MPG
1988 GMC SOLD
1992 K2500 LD 4x4, 5.7, 700r4, 3.73 14-bolt, G80, Cleaner than sh!t.2001 Tahoe LS 4x4(the wife's), 5.3, 3.73, G80, third-row seats.
Well I bought the truck back in '09, I think either the PO had it off or I took it off and just capped the EGR valve and inlet on the TB, so I got a new solenoid and hooked it all back up, 18 bucks later and I will watch my MPG and see what I get, I hope about .5-1 MPG better on the interstate.
1988 GMC SOLD
need some tow mirrors on that bad boy
'04 CTS-V | CS Diff Bushing | ALRADCO | 180* T-stat | Revshift MM's | Revshift TM | BMR Pinion Brace | 245/45R18 BFG Comp-2's
''00 MR2 Spyder | 225/45R16 - Rear, 215/40R16 - Front BFG KDW's | 138hp
I am the master of my fate; I am the captain of my soul.
Because the engine is tunes to expect that gases from the EGR will be circulated back into the engine and puts in enough fuel to mix with them (mainly the oxygen) for combustion. Without these gases you will be putting in the same amount of fuel but getting less combustion (running rich). Hooking it back up will bring the engine back to stoichiometric (proper air fuel ratio) combustion. Making more horsepower with the same amount of fuel, which in turn means less throttle input for a given output, less fuel put into engine, less fuel burned, improved fuel economy. :)
-Pat
"I drive it like I built it.... poorly."
EGR really is only engaged at a crusing speed, i.e. my two hour drive each way from school every couple weeks, long trips to IL, and to PA this summer, granted I have done more mods since I removed it, but I did not gain any performance by leaving it unhooked and if anything it hurt my MPG.
This is the reason I am hooking it back it, will hurt nothing and can only help, and it didn't cost much for a new solenoid and I have only anything to gain.
1988 GMC SOLD
1997 ECSB K1500... 350; 4L60E; 3.42 gears; G80 Locker; 0411 ECM; 3/4-ton Calipers and pads; Hydroboost and 3500HD Master Cylinder + Door Handles; 31x10.50x15's on OOBS Rallys
FUTURE PLANS: NV4500, 14BSF, 4.10s, 33's, 4" Lift, Urethane Bushing Kit, More I haven't thought of...
put used tires on the Tahoe
put led cargo lightspics in a bit
BEFORE BEFORE BEFORE
AFTER AFTER AFTER !!!!
it lights up an area behind me as well but ill just wait ofor my backup lights to come in
