Better you shoveling that then me![]()
This is a discussion on What did you do to your FSC today? within the Technical / Maintenance forums, part of the General Discussion category; What did I do with my fullsize....I used it today to haul a 3/4 ton of top soil. Sent from ...
Sent from my DROID BIONIC
1994 - Chevy z71 ECSB, spintech prostreet dumped, Magnaflow Y-Pipe 23256, 5,000k hids, Leveled on 265/75/16 Wardens E rated
2004 Impala - DD
xbox live tag : jrp12357
'95 GMC Z71|L05|GT4|Yukon 17s|Belltech|Purple Keys|FastChip|Hedman|Borla Pro|XtremeFI|Goodmark|Kenwood|Memphis|Ultimate TBI Mods|E Fan|
Much More to Come...
5200 lbs. at 12.4/15.9MPG
1988 GMC SOLD
Yea. Next year im looking into installing a bolt on hydraulic dump for my stock bed. Will be easier emptying the bed.
2004 Impala - DD
FOr sure, then you could make some money on the side too.
1988 GMC SOLD
04.5 Silverado 2500HD Duramax
03 Sierra ecsb 4x4 4.8l 3.73 4l60e
2004 Impala - DD
Not to terrible, brace it up and take a weekend to install and on your way.
1988 GMC SOLD
havent been on in a long time. last night i threw some factory steelies on after i painted them black and mounted some tires. she was a little too low for the pot holes around here tho so i took them off. think ill call them my "show rims"![]()
That sits nice.
2004 Impala - DD
ill put it on a *dyno* soon. Its gonna be pulling some huge numbers so be ready!
*edit*my new phone decides that synopsis is what should bs entered when I type dyno
2002 GMC Sierra. ECSB. 5.3 LM7. 4L60Etotaled 11/25/2012. R.I.P.
Not the cleanest job, but I blacked out the 'dead' gauges in the cluster. Replaced the stepper motor in the Speedo and mounted the mechanical gauges. I know it doesn't look like much, but it's much cleaner than how it was before.
Thats just water on the steering wheel. Weird weather in northern Az, sideways rain on a sunny day.
A couple more little projects to do before I take off on the road trip. I'm even thinking of installing a home made PCV/oil catch can. I am debating installing turn downs after my FM's or just leaving them open.
My trailer fenders didn't make it in time for me to mount them up before I go, so it looks like I'll be running mudflaps to Cali from Az. Hopefully that's good enough. Later I'll make a fuel pump mount with the aluminum angle stock.
Drove it for 2 hours from training to home. TGIF!
I spent about 7.5 hours of doing a damn tune up on mine. I have a thread in maintenance area. Was a nightmare. Everything was breaking and just not going my way. But now she runs great.
2004 Impala - DD
Got rid of some mods and returned things back to stock. About a year ago I got a radiator out of a junk yard. It was 28 inches wide instead of the stock 20'' which I thought was no big deal until I put it in. First, the fan shroud didn't fit and the ends of the radiator stuck out from the sides. I fabricated radiator mounts, but later discovered that instead of pulling air through the radiator and A/C condensor, the fan was pulling air through gaps between the fan shroud and the oversized radiator. Then I discovered that the drive belt was interfering with the lower radiator hose which now was in a different position because of the wider radiator so I removed the air pump and installed a shorter belt which solved that problem however resulted in lots of noise when I turned the A/C on. I could have installed an idler pully, but the air pump is essentially that once you remove all the pollution junk connected to it, so I stuck it back in, got a correct sized radiator and reinstalled the original belt. It all works much better now.
Hitched a 28' bumper pull camper to her. Going for a short camping trip this weekend.
97 ECSB with 256,00 and counting on a 5.7
went to the 1/8th today to see what kind of gains I got over stock with my meager collection of go parts. I expected to be the slowest there but it turns out I actually had a few cars I could pick on. Bunch of V6 Mustangs there, ... probably my best competition. Bit faster than a stock automatic and a bit slower than a 5 speed with a decent driver. Not much bragging rights there, but a V6 full size keeping up with a V6 sports car is good enough for me until my V8 swap![]()
Diva de los Muertos
1999 Silverado ECSB W/T . 4.3L . 101K . 2WD . Storm Gray Metallic
18" Titans . Falken 265/60 . EBC Pads/Rotors . FM40 . Silencer Delete . Modded TB . 93 BB Tune
Next: 4.30s . Roll Pan . 2/3 Drop
V8 when "finished"
YouTube
1992 K2500 LD 4x4, 5.7, 700r4, 3.73 14-bolt, G80, Cleaner than sh!t.2001 Tahoe LS 4x4(the wife's), 5.3, 3.73, G80, third-row seats.
LOL at the mustang being called a sports car...im a mustang fanatic but its no sports car. also the new 2012+ v6 mustangs are 305hp from the factory so youre still gonna have so stiff competition....and earlier cars with the 4.2 out of an f150 will surprise you esp if they are boosted
