Results 1 to 15 of 15
94' silverado loses all power--then is fine again
This is a discussion on 94' silverado loses all power--then is fine again within the Technical / Maintenance forums, part of the General Discussion category; ok this is driving everybody crazy--94' silverado 1500 ,after the truck warms up it starts to cut out .when i ...
    Mar 2010
    oly,pia
    ok this is driving everybody crazy--94' silverado 1500 ,after the truck warms up it starts to cut out .when i give it more gas it does not react but after a few seconds it all catches up and goes for a couple of minutes and then boom--cuts out and does it again-.all engine codes have been addresed and the list of things replaced is quite long. I had a certified mechanic drive it and he did not know what the problem was either.ANYBODY that has had this problem and figured it out I would be forever grateful-
    GMC RULZZ NEUMANNZZ's Avatar
    Mar 2005
    San Diego
    Re: 94' silverado loses all power--then is fine again
    list out the things replaced.
    cts sensor or 02 sensor could cause problems after warm up. fuel pressure good when warm?
    Matching Ninja 500r
    Registered User The-Redneck's Avatar
    Mar 2010
    Red Deer, Alberta
    fuel filter.
    1995 GMC Sierra 2500 4x4 5.7L 5 speed manual W/T
    Mar 2010
    oly,pia
    here is the list of replaced items
    iav valve
    egr solenoid
    map sensor
    o2 sensor
    temp sensor
    temp sender
    fuel injectors
    fuel pressure regulator
    fuel sending unit w/ pump
    ecu
    prom
    tps
    fuel filter
    new plugs
    plug wires
    new dist cap/w rotor
    factory rebuilt transmission
    as you can see this is becoming quite irratating and it is not something simple like the fuel filter-hence the driving me crazy part-
    Mar 2010
    oly,pia
    fuel pressure is fine when warm- this has really got me stumped-
    Registered User HUMP's Avatar
    Dec 2009
    Arkansas
    Have the coil and pickup been checked?
    Mar 2010
    oly,pia
    coil is new pick is fine also--one more thing I can add that might be of help is that it all started after a new exhaust system-not sure if it has anything to do with it or is mere coincidence
    Mar 2005
    San Diego
    maybe they damaged the o2 sensor welding on the exhaust, or the sensor wires rubbing on the exhaust and melting.
    Matching Ninja 500r
    Mar 2010
    oly,pia
    well will check the sensor -dont suppose you know an easy way of doing that do ya ? umm say ....like what the voltage is supposed to be ?
    Mar 2005
    San Diego
    your gonna need a scan tool to check o2 sensor operation. I would at least look under there and check the wiring.
    Matching Ninja 500r
    Registered User Dev's93's Avatar
    Mar 2010
    Shelbyville , IN
    ignition switch?
    Sep 2006
    Arizona
    electronic ignition module
    OBS Obsessed 94Z-Buggy's Avatar
    Dec 2007
    La Grange, NC
    an o2 sensor is not that intricute in the operation of an OBD 1 system. i had a 94 burb that had no o2 sensor on it, drove it like that for about a year, it just makes the truck run a little rich and have an aggrivating orange glow coming from the dash.
    1994 Chevrolet Silverado Z71 ECSB
    3" lift-305/70R17 Buckshots-17x10 Gear Alloy Modified-True Duals-Smoke Tint
    227K on the clock
    Aug 2003
    Virginia
    Did you ever resolve this issue? i have a 98 silverado and i'm going down this same road....Wont throw any generic codes with service engine light, but i know something is wrong...I hate to take to pay for diagnostic scanning when it could be a simple sensor....Any insight appreciated..
    Scott Freeman
    Mar 2005
    San Diego
    Quote Originally Posted by smfreema View Post
    his truck is tbi, totally different fuel injection and computer system. start a new thread.
    Matching Ninja 500r
