Results 1 to 5 of 5
97 Z71 locking rear end?
This is a discussion on 97 Z71 locking rear end? within the Technical / Maintenance forums, part of the General Discussion category; I couldn't find info any where else about this, but my question is I just bought a 1997 Chevy 1/2ton ...
    Never Satisfied! bigred70k20's Avatar
    Jun 2008
    Polk County, WI
    I couldn't find info any where else about this, but my question is I just bought a 1997 Chevy 1/2ton Ext Cab 4x4 with the Z71 option code. I looked at all the option codes and I found that it has 3.73 gears but it doesn't have the G80 code any where in the option code list. Did the Z71 trucks come with a locker or limited slip in the rear as part of the package or since there is no G80 code do i just have an open rear end?
    1997 Chevy 1500 Z71 4x4, Vortec 350, 3" body lift, torsion bars cranked, 285-75-16 Daytons, dual exhaust, Delta Toolbox
    1970 GMC K-25 3/4ton 4x4, 6in lift, 35" BFG A/T's, Built 350, Dana 60 rear, Dana 44 front, 5.13 gears
    miss you Rachael tatoodkelt's Avatar
    Dec 2006
    Bowie, Maryland
    Re: 97 Z71 locking rear end?
    Looks clean man. If there's no code, its not there. I have two with the Z71 code, one has the G80 code.
    70 Chevelle * 73 Chevelle * 87 K5 * 94 RCSS * 95 2dr Tahoe * 99 Suburban * 03 Yukon
    70 Chevelle rebuild here
    Quote Originally Posted by JWolfe75 View Post
    I'm also a pop-in-pooper......
    Sep 2009
    MN
    You just got an open rear.
    2000 Chevy Silverado Z71
    5.3L 4.10's G80
    0_o o_0 0_o o_0 98GreenMachine's Avatar
    Aug 2005
    St. Paul, MN
    Not all Z71's got the G80. Some would say your lucky you don't have it
    Mine does...
    98 K1500 Z71 - 204k | L31 | 60E | 3.73's | 3" BL | 33x12.5x15 Dick Cepek F-C II's | Dynomax Ultra Flo X DI/DO | 14 MPG
    Jun 2008
    Polk County, WI
    Thanks. I wasnt sure if it did or not being a z71. I am glad i dont have it, my last truck didnt have it either.
