Results 1 to 13 of 13
1988 Suburban 5.7 TBI, Just died!!!
This is a discussion on 1988 Suburban 5.7 TBI, Just died!!! within the Technical / Maintenance forums, part of the General Discussion category; I started it up, Let it run fir 5 min, then Pow!!! It just died! Everthing has power, It turns ...
    Registered User Widmayer's Avatar
    Oct 2008
    Illinois
    I started it up, Let it run fir 5 min, then Pow!!! It just died! Everthing has power, It turns over, just no fire! I cannot find anything wrong! Checked all fuses and the ECM Fuse was blown, Replaced it and still nothing.
    Any help or directions would be Great.
    Sep 2009
    MINNESOTA
    Re: 1988 Suburban 5.7 TBI, Just died!!!
    when you replaced the ecm fuse and cranked it over again did it blow the fuse again?
    NEW 2004 Sierra D-MAX
    Oct 2008
    Illinois
    Nope, Fuse is good.
    Sep 2009
    MINNESOTA
    possibly could have fried the ecm. try a crank relearn maybe? could be your best bet.
    Oct 2008
    Illinois
    Replaced the Ecm, Still the same.
    But now I found that my Headlights dont work.
    Sep 2009
    Maine
    Start with the basics. Fuel pressure, spark.
    Oct 2008
    Illinois
    I have fuel pressure, No spark.
    I think a wire is fried, If this was a older car, I'd say it was a fusable link.
    Jul 2009
    Westport, MA
    there has to be a wire shorting out somewhere causing your issues. Pull out one fuse at a time and see if your truck starts. Ovioulst dont pull the fuses for the things your truck needs to run. Try pulling the fuses for the lights, wipers, etc. If the truck starts with one of those fuses out then your electrical issues is in that circuit
    Sep 2009
    Maine
    Could be the distributor or coil.
    Oct 2008
    Illinois
    Here is what i found,There is no power to or from The ECMB Fuse, I ran 12 V to the top of the fuse and she fired right up. So i am pulling the fusebox out.
    Oct 2008
    Illinois
    Traced lack of power to starter, Found a Fusable link smoked.
    Sep 2009
    Maine
    Glad you found it. Keep an eye on it, that fusible link melted for a reason.
    Apr 2010
    NJ
    nice job dude i hate electrical stuff, it just befuddles my mind and makes my head hurt when i try to figure them out haha
