GM Inside - Muscle Cars - Jeep
Results 1 to 5 of 5
96 vortec not running right
This is a discussion on 96 vortec not running right within the Technical / Maintenance forums, part of the General Discussion category; 1996 chevy 350 tbi engine, will start, idle roughly, once put into gear will die unless feathered. Once under way ...
    Jan 2010
    Cow Bay, Nova Scotia
    1996 chevy 350 tbi engine, will start, idle roughly, once put into gear will die unless feathered. Once under way will not accelerate. If given lots of throttle underway will simply die, fuel filter replaced with no improvement. Also when in neutral you can rev the engine up without it bogging. It will only bog and die when in gear. New plugs and wires also.
    Sep 2009
    MINNESOTA
    Re: 96 vortec not running right
    how did your old plugs look?
    did you check fuel pressure?
    NEW 2004 Sierra D-MAX
    Jan 2010
    Quote Originally Posted by brettj2408 View Post
    old plugs looked pretty fowled up. Im not sure how to check the fuel pressure.
    Sep 2009
    MINNESOTA
    attach a fuel gauge to your shrader valve on your fuel rail
    Jan 2010
    I'll try that tomorrow. Any more ideas? Thanks for the help.
