Results 1 to 9 of 9
98 vortec 5.7 with problems
This is a discussion on 98 vortec 5.7 with problems within the Technical / Maintenance forums, part of the General Discussion category; i have a 98 5.7 in my GMC. the problems i have is #1,3,7 spark plugs foul out with a ...
    Jun 2010
    bradford, ma
    i have a 98 5.7 in my GMC. the problems i have is #1,3,7 spark plugs foul out with a beige soot on them(only those 3), low on power, bad gas mileage, runs lean(pings). i already have the intake off and i found a slight problem on the lt rear gasket port(it goes nowhere on the intake, its flat, what would be a coolant passage) im concerned that it could be a head gasket. what are your thoughts?
    potato gon' potate SlvrdoHDmax's Avatar
    Aug 2008
    Jackson, Missouri
    Re: 98 vortec 5.7 with problems
    It could be the lower intake gaskets. Does your coolant level change any?
    Jun 2010
    bradford, ma
    Quote Originally Posted by sw45 View Post
    yes it does but its minor. i did a pressure check on the cooling system and it looses about 5 psi in about 10 minutes. no external leaks.
    bikes cars trucks women vic_V8's Avatar
    Jan 2004
    Dixon IL
    coolant isn't showing up in the oil is it?
    '84 K30, 7" lift, Converting to International Diesel HP 60/14 combo
    '88 GMC Suburban V2500 5" lift 60/14 with 4.10s 5.3 LS swap TH400/NP208
    '94 GMC Suburban K1500 350/4L60e with updated heads, mild upgrades
    '77 Ford F250 High Boy 400/C6/Divored 205 44/60
    Veteran of Afghanistan (Army SSG)
    Jun 2010
    bradford, ma
    Quote Originally Posted by vic_V8 View Post
    no, and the level is not reading higher either. no smoke out the exhaust, no CEL. passed emissions with flying colors last month. it has been doing this for about 9 months. just got around to it today.
    Jan 2004
    Dixon IL
    do you have dual cats?
    Jun 2010
    bradford, ma
    yes
    Jan 2004
    Dixon IL
    I was having some stumbling problems, did a full tune up and still had some, turns out I had a clogged cat.
    Registered User bwood's Avatar
    Mar 2003
    Denison, Texas
    Lower intake gasket failures are common on these trucks. They will generally fail on the pass rear of the intake where you mentioned. They will leak down the backside of the engine or into the lifter valley contaminating the oil. In some cases, the leak can be slow enough that when the oil gets hot enough, it will turn the water to steam and will be burned off through the pcv system. Look under the oil cap for a light colored sludge. This is a sign of water contamination in the oil. The coolant passage and the intake passage are far enough apart that the coolant would have a hard time getting into the intake ports (the closest one to the sight of normal failure would be #7). The part # for the newest intake set is Fel Pro MS98000T. This is the latest design that uses rubber over steel instead of a rubber oring in plastic. This set is a little more expensive, but if you follow the installation proceedure, you should never have another issue with this leak.
    If you do suspect a clogged cat, unplug and remove the upstream O2 sensor on the same side of the effected cylinders (#1,3,5,7 are on the driver's side). Then run it and see if it feels any different. This is only for diagnostic, and it will set the light for the missing O2.
    Also, a cat doesn't just plug up. Generally, another issue in/on the engine led to the converters failure. Phosphorus, lead and silacone can coat the converters surface inside and eventually cause a clogged cat. Phosphours comes from oil (although, newer oil formulations have reduced amounts of phosphourus), lead from leaded fuel (not pump gas) and silacone from coolant.
    1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
    -Gibson Stainless Cat Back Swept Side
    -255/70 BFG Radial T/A on SS 15's
