Results 1 to 6 of 6
1996 vortec 350 orange spark
This is a discussion on 1996 vortec 350 orange spark within the Technical / Maintenance forums, part of the General Discussion category; correct me if im wrong, i should be having bright blue spark. i am having orange. i am also haveing ...
    joseph_zlnsk Joseph_zlnsk's Avatar
    Jul 2010
    morgan city LA
    correct me if im wrong, i should be having bright blue spark. i am having orange. i am also haveing what seems like mis fires, generally just running like crap. changed my ignition control module. changed my coil with an older one that i have as a spare. but if i change it again. and still getting orange spark what else could be the problem. i have new plugs, wires, rotor, and cap. anyone know?
    Aug 2010
    kent,il
    Re: 1996 vortec 350 orange spark
    orange would be colder spark i would think... because orange fire is colder than blue rite? so maybe wrong heat range of plugs or wrong gap?
    May 2010
    SFLA
    what kinda voltage is getting to the coil?
    Jul 2010
    morgan city LA
    im not sure. i have put a calibrated tester to the coil though and the coil is only producing orange spark. i just went and bought a new coil. so we will see what happens after i put that in there. how do u guys recomend that i test the voltage from the coil. i have a voltameter so tell me how i can safely check the voltage.
    Apr 2010
    Piedmont of NC
    Quote Originally Posted by Kick3500 View Post
    Quote Originally Posted by Joseph_zlnsk View Post
    im not sure.
    Then check it please...
    Throwing parts at a problem will get you no where... FAST! Other than more frustrated & broke simultaneously!
    Don't worry about the OUTPUT for now, check the INPUT with your voltmeter...
    '99 Suburban 2500 Base Model 5.7L-4L80E-SF 14B-Hydroboost @180K
    '72 Jeep Commando ("Mossy") AMC 304 w/ GM TBI-TH400-D20-Locked D30-Welded D44-33" Swampers-Full Cage-Bumpers & Winch
    Jul 2010
    morgan city LA
    oh would u tell me how to safely and correctly check the intake to the coil. and when i test it what should my readings be?
