Results 1 to 11 of 11
1999 Suburban/Tahoe keyless entry remote, what does it look like?
This is a discussion on 1999 Suburban/Tahoe keyless entry remote, what does it look like? within the Technical / Maintenance forums, part of the General Discussion category; I bought a 1999 Suburban equipped with keyless entry but came with no fobs. I had to replace the module ...
    Floor it!
    Mar 2003
    Houston, TX
    I bought a 1999 Suburban equipped with keyless entry but came with no fobs. I had to replace the module though because it wasn't working, so my keyless entry module is from a 1999 Tahoe, I hope the fobs are the same.... however I can't tell what to look for. I see fobs on ebay and other places and they are all different (some of them have the truck pop button on it, some have "Rear 2x". What does your fob look like?
    1999 Suburban 5.7 LT 1500 2WD
    Jun 2009
    S. Vermont
    Re: 1999 Suburban/Tahoe keyless entry remote, what does it look like?
    1999 Chevy Suburban
    Floor it!
    Mar 2003
    Houston, TX
    Thanks for the pics, I can't read the numbers on the back, what are they?
    Captain Dickface Cartman372's Avatar
    Oct 2009
    Newton, NJ
    1999 Chevy Tahoe LS (4WD/4DR/Barn Doors)
    As you can see, it's had some use over the years
    Back:
    Numbers on the back are;
    GM: 16245100-29
    Canada: 218101368
    Model/FCC ID: AB01502T
    Use the top one (16245100-29) if you plan to order it from ebay or any other place.
    Floor it!
    Mar 2003
    Houston, TX
    Oh cool your's has a horn button on it, I'm gonna look for one of those!
    Oct 2009
    Newton, NJ
    Quote Originally Posted by bigburb View Post
    Well, I wouldn't worry about it that feature...I can't get it to work on my truck.
    Floor it!
    Mar 2003
    Houston, TX
    Oh, well I guess that explains why most remotes I find don't have it.
    Oct 2009
    Newton, NJ
    Well I've seen the GMT400 Escalades and Yukon Denalis use the same type of keyfob as mine (with the horn button) and it's a working feature on them.
    I don't know what the difference is between the two when it comes to that feature but I'm, sure someone could chime in.
    aka Richard
    edit: Just remembered, on the GMT400 Escalades and Denalis, their lights also flash when locking/unlocking them. So I'm sure there's a difference between the two when it comes to that.
    2nd Amendment Supporter mudbuddy's Avatar
    Sep 2007
    S.E. Wi.
    The red horn button is a panic button you can press and the horn starts beeping while your getting raped or you lose your Escalade at the mall.
    Oct 2009
    Newton, NJ
    Quote Originally Posted by mudbuddy View Post
    Well, is there anyway to get it to work with my Tahoe? It's not like I'd ever need to use it for either use (OBS keyfobs range is an amazing 5 feet...)
    But I'd like to have a working button...
    Oct 2009
    grand rapids MI
    doesnt the horn/panic button only work w/factory alarm? my wifes blazer has the panic button and also factory alarm. whilest my burban has no alarm and no panic button.
