Results 1 to 4 of 4
2011 silverado cab mounts
This is a discussion on 2011 silverado cab mounts within the Technical / Maintenance forums, part of the General Discussion category; I was taking the cab mounts out tonight to put my new nerf bars on and twisted the insert in ...
    Oct 2009
    missouri
    I was taking the cab mounts out tonight to put my new nerf bars on and twisted the insert in the middle cab mount. Is there a way to fix it, or get the bolt the rest of the way out? Please, I need help quick
    Mar 2007
    HOUSTON
    Re: 2011 silverado cab mounts
    You got to pull the seat and there is a plug in the floor for access to the nut. It seems to be happening to alot of them.
    Oct 2009
    missouri
    Was the nut welded to the cab or does it just have a keeper or something?
    Aug 2010
    in my house
    Welcome to the club.......2010 here.....and the 2 middle bolts also. I heard grapevine rumor that GM is aware of this and that they've come up with a procedure to remedy, but taking the seats out is not the way as there is not an access plate to them.....so I've been told. I know a mechanic who works at our local GM dealer and had talked to him about mine, but have not heard yet if it's going to be warranteed. 4 months later, I'm still driving around with 2 bolts loose.
