Results 1 to 9 of 9
350 tbi intake manifold gaskets (oil leak)
This is a discussion on 350 tbi intake manifold gaskets (oil leak) within the Technical / Maintenance forums, part of the General Discussion category; Haynes talks about installing front/rear seals after the gaskets. I'd think RTV will do the job? Noticed an oil leak ...
    Oct 2010
    north-central PA
    Noticed an oil leak today on back of engine, pulled the valve cover hoping it was that easy. Nope. Bought a $.99 distributor gasket, pulled the distributor. Nope. Appears to be the seal between block and intake manifold.
    I did gaskets on a 4.3vortec, and the 350tbi looks like it will be much easier unless I'm missing something... looks like I can remove the intake manifold without having to monkey with the P/S pump?
    Confirmation appreciated..
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Re: 350 tbi intake manifold gaskets (oil leak)
    DO NOT use the included end seals that come with the gaskets, use RTV, a 1/4" bead along the block front and rear will seal it good
    make sure everything is clean and oil free, and if possible, get it all together and let it sit overnight before starting it
    other then the gasket scraping, yes, it is a little easier then a vortec intake job
    2000 Silverado 6.0 4L80E 2wd
    Registered User Blue 04 Z71's Avatar
    Sep 2007
    Reading, PA
    Yea pulling the manifold is not a huge task. You don't have to mess with the ps pump. Just basically leave everything on except the dizzy and disconnect a few wires and it should be able to come right off. And RTV the ends don't use the gaskets they push out and leak. And bring the rtv up onto the manifold gaskets about 1/4 to a 1/2 inch so you get a good seal.
    04 1500 Z71 6.0 LQ4 swap, BlackBear 06+ Grill/Hood, Vette servo, 3 BL,RC Keys, Truxedo, Bull Bar,KC, Cooper ST's Bilstein 5100's Tow's, Pypes M-80.
    1989 Silverado 2500 94+grill, Ram air hood, Mild built 355, Th400,
    Oct 2010
    north-central PA
    sweet, thanks guys.
    I can see the bulging rubber seal next to the oil pressure fitting, and that's what's leaking. I think all the felpro sets even come with rtv instead of preformed seals.
    Registered User JoeTech's Avatar
    Nov 2008
    The State of Jefferson
    Permatex "Right Stuff" works 1,000 times better then RTV.
    ASE Certified Technician
    California Smog Check Technician
    97 Chevy C1500--02 Chevy K1500--69 Chevelle--69 Volkswagen Beetle
    "Educate and inform the whole mass of the people... They are the only sure reliance for the preservation of our liberty"
    Thomas Jefferson
    www.CampaignforLiberty.com
    Registered User 454cid's Avatar
    Mar 2003
    West Michigan
    What's wrong with using the provided seals?
    454cid
    1999 K3500 RCLB
    Nov 2008
    A nice thick bead of right stuff just works a whole lot better. Some gasket sets come with sh*ty cork end seals witch just don't work, other sets come with rubber end seals that can leak, shrink, get hard and you still need some kind of sealant in the corners where the heads meet the block.
    Thomas Jefferson
    Feb 2010
    SW OH
    Only one minor detail...
    They leak.
    If that doesn't bother you, then they're fine.
    Smear a thin smear of sealant on the block. Lay a bead about " tall on it. Let it set up for about a half hour. Smear a thin layer on the intake and add a thin coat onto your bead, and put the manifold on. Tighten the bolts to about 5 ft-lbs - basically, just past finger tight. Let set up overnight. Torque to specs.
    Mar 2003
    West Michigan
    I've never done an intake* myself, but I can see what you're saying happening. My Buick has rubber end seals and they look like they're coming out, and I've never been able to get the idle as low as I should be able to....... vacuum leak. On my truck a corner or two were neglected in Tonawanda according to the mechanic that did the intake gasket. I don't know what he used in the corners, but it looks questionable to me, as it's fairly hard. I'll be doing it next time, since I need to pull the heads, now.
    *On a V engine only inlines
    454cid
    1999 K3500 RCLB
