Results 1 to 4 of 4
5.3 Spark Plug Gap
This is a discussion on 5.3 Spark Plug Gap within the Technical / Maintenance forums, part of the General Discussion category; My 02 Silverado just turned 100k miles, so I thought I'd replace the spark plugs. I bought ACDelco 41-110 plugs ...
    Aug 2005
    Ohio
    5.3 Spark Plug Gap
    My 02 Silverado just turned 100k miles, so I thought I'd replace the spark plugs. I bought ACDelco 41-110 plugs and they are gapped at .040". The dealers" book calls for .040 also. My owners manual and the tag under the hood calls for .060". Can the iridium plugs be regapped from .040" to .060" or have the specs changed from .060" to .040"? Don't really know which is right. Any help would be appreciated.
    Aug 2009
    C.A. High Desert
    Re: 5.3 Spark Plug Gap
    Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
    Models: 2004 Buick Ranier
    2002-2004 Cadillac Escalade, Escalade EXT
    2003-2004 Cadillac Escalade ESV
    2004 Cadillac CTS-V
    1997-2004 Chevrolet Corvette
    1998-2002 Chevrolet Camaro
    1999-2004 Chevrolet Silverado
    2000-2004 Chevrolet Suburban, Tahoe
    2002-2004 Chevrolet Avalanche
    2003-2004 Chevrolet Express, TrailBlazer
    1999-2004 GMC Sierra
    2000-2004 GMC Yukon, Yukon XL
    2001-2004 GMC Yukon Denali, Yukon XL Denali
    2002-2004 GMC Sierra Denali
    2003-2004 GMC Envoy XL
    1998-2002 Pontiac Firebird
    2004 Pontiac GTO
    2003-2004 Hummer H2
    with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
    A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used..
    Aug 2005
    Ohio
    Thanks, desrtrat, I appreciate the info.
    gary
    Sep 2009
    Maine
    Whether you use Iridium, Platinum, or Copper; gap should be .040"
