Results 1 to 6 of 6
454 vortec hard starting all the time...
This is a discussion on 454 vortec hard starting all the time... within the Technical / Maintenance forums, part of the General Discussion category; my buddy has a 454 vortec in his truck and to start it you crank it any where 5-10 seconds ...
    Registered User chevybarr's Avatar
    Feb 2011
    Warren, In
    my buddy has a 454 vortec in his truck and to start it you crank it any where 5-10 seconds everytime warm or cold b4 it'll start, once it is started it runs like new but starting is hard, it's not weak battery it cranks like it should(nice strong and fast crankin)...what could his problem be? doesn't burn oil, runs good once started we r stumped
    Registered User Mr_Shamrock's Avatar
    Jan 2011
    Greenville, SC
    Re: 454 vortec hard starting all the time...
    I would start with a fuel pressure check and leak down test. Sounds like the pump might be leaking down.
    so cheap it's scary Stratosman's Avatar
    Oct 2007
    Kentucky
    injectors, Dad's did that for 2-3 years before he finally replaced them, starts right up now
    Used to own a FSC, now I just have my extremely old Buick.
    Have some perspective please. Thank you.
    Feb 2011
    Warren, In
    ya after i posted this i searched and found alot about it and easy upgrades, im guessing this is the problem since most people have this problem...any other ideas are welcome thanks for quick replys!
    Sep 2009
    Maine
    Quote Originally Posted by Mr_Shamrock View Post
    Do this first.
    Quote Originally Posted by Stratosman View Post
    Then this.
    Registered User 2500ak's Avatar
    May 2007
    Alaska
    My guess is FPR. A failed fuel pressure regulator can cause long cranking times. When was the last time you changed the fuel filter? If the injectors are bad enough you can often see them dripping if you look at them when the engine is running, that's a dead give away. The mist should be fine, uniform, and not dripping.
    Transgo HD2 | Magnaflow DI/DO | CAI | BlackBear Tune| Dual Optima Red Tops: 2000 Cold Craking Amps | Denali Projectors |
