Results 1 to 5 of 5
6.0L Spark Plug Gap Discrepancy 0.060 or 0.040??
This is a discussion on 6.0L Spark Plug Gap Discrepancy 0.060 or 0.040?? within the Technical / Maintenance forums, part of the General Discussion category; I picked up an 01 1500HD CCSB with the 6.0L (LQ4 I believe). The truck doesn't get very good mileage. ...
    Jan 2004
    Ontario
    I picked up an 01 1500HD CCSB with the 6.0L (LQ4 I believe). The truck doesn't get very good mileage. At times it feels like it's towing a trailer or under load all the time. I scanned it tonight and had no codes either. I am getting about 400 kms to 80L, back roads, no stop and go.
    I pulled a plug tonight to have a look, and it has Declo Platinums, 41-985. They're gapped at .040. The air breather says .060... I looked up the plugs on Rock Auto and they're all calling for .040 and not to deviate from it.
    Can anyone clarify for me what the correct gap is?
    Thanks
    2008 GMC Sierra Z71 Ext Cab
    1997 Silverado Z71 Ext Cab - Stolen, Recovered and being rebuilt
    0 Fvcks Given TheBigBlackHD's Avatar
    Oct 2006
    Central NC
    Re: 6.0L Spark Plug Gap Discrepancy 0.060 or 0.040??
    The correct gap is whatever it says under your hood. Alldata says .060. I'd get some new plugs, dont gap the ones you have as platnium plugs you arent supposed to gap (so I've heard).
    Jan 2004
    Ontario
    I double checked the plugs with another parts house and they're calling for the plug I have with an .040 gap. I asked about a regular not platinum plug and AC Delco didn't have one I was told. I wanted to put in a regular set at .060 and see if the mileage was better.
    Aug 2009
    C.A. High Desert
    this has been posted before...
    Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
    Models: 2004 Buick Ranier
    2002-2004 Cadillac Escalade, Escalade EXT
    2003-2004 Cadillac Escalade ESV
    2004 Cadillac CTS-V
    1997-2004 Chevrolet Corvette
    1998-2002 Chevrolet Camaro
    1999-2004 Chevrolet Silverado
    2000-2004 Chevrolet Suburban, Tahoe
    2002-2004 Chevrolet Avalanche
    2003-2004 Chevrolet Express, TrailBlazer
    1999-2004 GMC Sierra
    2000-2004 GMC Yukon, Yukon XL
    2001-2004 GMC Yukon Denali, Yukon XL Denali
    2002-2004 GMC Sierra Denali
    2003-2004 GMC Envoy XL
    1998-2002 Pontiac Firebird
    2004 Pontiac GTO
    2003-2004 Hummer H2
    with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
    A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
    Jan 2004
    Ontario
    Thanks for posting that information, much appreciated
