Results 1 to 13 of 13
Whereis my knock sensor located on 5.7 liter Vortec motor
This is a discussion on Whereis my knock sensor located on 5.7 liter Vortec motor within the Technical / Maintenance forums, part of the General Discussion category; I cannot find my knock sensor???? I have a code saying it is bad,butcannot findit to replace it??...
    Registered User bowhunter920's Avatar
    May 2009
    Craig Co, Va.
    99 Chevy 1500 classic with 5.7l, Z71, Lifted with 6" RCX, torsion keys, 35" BFG Km2s on Mickey Thompson Sidebiters, optima red top, dual flowmasters, ranch hand bumper....
    Dec 2010
    Dallas, TX
    Re: Whereis my knock sensor located on 5.7 liter Vortec motor
    it is right behind the starter on the passenger side...unfortunetly you have to remove the starter to take the sensor off.
    Did you ever figure out your overheating issue.
    FastOrange BlacK20's Avatar
    Nov 2010
    Williams Lake, BC!
    1978 K20 RCLB, 400 SBC, 4-Speed, Lifted
    1998 Pontiac Grand Prix GT, Coupe
    Addicted to EFI ! Eagle-Mark's Avatar
    Jul 2008
    North Idaho
    YOUR KS is a little low...
    Jul 2008
    North Idaho
    To the origanl poster, check the wire running to it as they are usually the culprit...
    OBS'r jsmitty74's Avatar
    Aug 2010
    Midland Texas
    I've never had to remove the starter to get to them......................
    They are on the passenger side of the block, about half way from front to back, and right above the oil pan gasket
    wah!
    If it ain't a Chevy, or a Peterbilt, it doesn't count!
    1996 1 ton crew, single wheel, 350, 4L80E
    1989 3/4 ton. Parked for good, ready for the salvage yard
    2003 Chevy Venture (wife's)
    Nov 2010
    Williams Lake, BC!
    Quote Originally Posted by Eagle-Mark View Post
    Ummm, nope.
    May 2009
    Craig Co, Va.
    Quote Originally Posted by stamp32 View Post
    I was wondering why I cant see it. I will remove my starter and look.
    No I have not figured out my overhaeting issue.... I found a crack in my radiator, maybe that is causing it.
    Jul 2012
    Tumbling Shoals, Arkansas
    I am having the same problem, but I can not trace the wire back to replace it. Can you tell us how to replace?
    Registered User MarkEagleUSA's Avatar
    Dec 2010
    CT
    Is the knock sensor in a water jacket where coolant will come pouring out when it's removed?
    Mark
    97 K2500, 5.7, 4L80E, 4.10 Posi
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Quote Originally Posted by MarkEagleUSA View Post
    Yes
    2000 Silverado 6.0 4L80E 2wd
    Mar 2016
    California
    It's exactly where the picture shows it. No need to move the starter, no need to drain the coolant.
    Sqeeze the plastic connector on the elongated ends and wiggle it off. Look at the wire end of the connector, if the wire looks frayed or the inside looks nasty, (mine was full of oil) now's a good time to go to your auto parts store and get a new plug and wire connector. Pack dielectric silicone in the wire connector before insertion of wires.
    You may want to LOOSEN the knock sensor while the engine is still warm with a 7/8" deep socket, but DO NOT REMOVE YET! Wait til the engine is COLD. Wear eye GOGGLES or FULL FACE protection, coolant will be streaming out. Have a wide container to catch the splattering coolant.
    Pack dielectric silicone in the electric connection of the NEW knock sensor and plug. Have the new knock sensor ready in one hand and remove the old knock sensor with the other. If you can swap them out on the first try, you may lose a cup or two of coolant. Tighten it up good. Push the plug on til you hear it pop into place and zip tie any loose wire. Fill with fresh coolant. Enjoy the more horse power! And maybe some of the other anomalies that you couldn't figure out disappear too.
    Mar 2016
    California
    While you're doing this, disconnect your negative lead to the battery. This will reset your computer and turn off the SES light.
