Results 1 to 6 of 6
symptoms of bad knock sensor
This is a discussion on symptoms of bad knock sensor within the Technical / Maintenance forums, part of the General Discussion category; my 04 z71 has had an engine light since i got, had it checked out and its a bad knock ...
    Aug 2010
    laredo, texas
    my 04 z71 has had an engine light since i got, had it checked out and its a bad knock sensor, what effects does it have on performance mileage etc.? would like to know if it "needs" replacing thks
    ballz2thewall budweiser's Avatar
    Dec 2010
    Central Florida
    Re: symptoms of bad knock sensor
    i have 2 bad knock sensors, truck is running like hell, no power off the line and excessive fuel consumption
    Aug 2010
    laredo, texas
    yeah i know there suppose to be some torque management but i drove a 05 suburban with no engine problems and it had more balls than my truck!
    Mar 2007
    MI/AZ
    When a KS code is set the PCM retards timing to protect the engine. Fuel economy and performance are affected. Get it fixed.
    Aug 2010
    laredo, texas
    ok defiantley gonna do that probably this weekend what would i need the sensor, intake gasket, rtv, what else?
    Mar 2007
    MI/AZ
    Two sensors, pigtail,intake gasket and there is a TSB (search) and intake gasket set.
    Quote Originally Posted by helix View Post
