Results 1 to 7 of 7
97 rear end interchange?
This is a discussion on 97 rear end interchange? within the Technical / Maintenance forums, part of the General Discussion category; Gentlemen, I have a 97 k1500 with a grinding/squalling rear end, and a few questions: 1. what is the difference ...
    Jun 2011
    charleston sc
    Gentlemen,
    1. what is the difference between the 14 bolt and the 10 bolt?
    2. what models and or years have interchangeable rear ends?
    3. does anyone know where i can find one? (LKQ wants $700, i told them to jump in a friggin lake)
    Nov 2005
    Lanark, Ontario
    Re: 97 rear end interchange?
    You need a 6 lug 4x4 axle from 88-98. 2wd axles are narrower.
    10bolt is tiny.
    14bolt SF is tough for a six lug axle. 14 bolt FF or Corporate 14 bolt is a 1 ton axle, not what you are looking for as it needs custom work for a 6 lug application.
    Registered User idriveafastcar's Avatar
    Jan 2012
    Central Wisconsin
    i had a 91 4x4 w/t 1500 chevy and that rear axle 6 bolt would not fit my 97 k1500 4x4 silverado 6 bolt. so if they were both 4x4 1500's why would the rims not interchange? was there two different 6 lug patterns?
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by idriveafastcar View Post
    No. 6 on 5.5" has been GM's 6 lug patter for a long time.
    Registered User daved931's Avatar
    Apr 2008
    Bangor, ME
    Quote Originally Posted by ninjaneer View Post
    Gentlemen,
    1. 10 bolt has 8.5" ring gear, 14 bolt SF has 9.5" ring gear. The 14 bolt SF is much, much beefier than the 10 bolt.
    2. Any 6 lug 14 bolt SF from 88 - 98 4x4 should bolt right in with a conversion u-joint. You'll need a 1310 to 1350 or an S44 to 1350. Parking brake cable should be reusable.
    3. I have found that Craigslist is your best bet. I looked around at salvage yards when I wanted one and they wanted $800 for one in just okay condition. I found a basket case for $150 and rebuilt it. For $1000 total, I had a really nice rear end.
    1999 2 Door Tahoe 4x4 w/ 14 Bolt SF & TruTrac. All kinds of upgrades, SOLD 1/2012
    2008 Silverado 1500 Z71, leveling kit, exhaust, SOLD 9/2014
    2014 Silverado 1500 Z71, stock for now
    Jan 2012
    Council Bluffs, IA
    It would be a tough find, but in the late 80's early 90's GM made some bottom of the line work trucks with 6 lug axles and corporate 14 bolt rear ends. I work for a lawn care company, and we have 2 of these "frankentrucks." They are both from 1989, have 3/4 ton suspension with the 14 bolt rears, 6 lug axles and no options whatsoever. Just a heater. One of them even has a 4.3 V6. Again a tough find, but they're out there.
    Registered User 92chev's Avatar
    Feb 2008
    Lincoln, NE
    ^pretty sure you're talking about just a typical 2500LD. Which would be the 6 lug 14b SF. The "corporate" 14b, like mentioned earlier, is a FF axle.
    6 lug 14b SF are a bit more uncommon now thanks to cash for clunkers, but search craigslist. I've found them for a couple hundred bucks
    1992 Chevy K1500 ECSB. 4.3L 5sp and tons of chrome. Beautiful to look at, miserable to drive
    1999 OBS Tahoe. Wait4Me tune, COMP 1.6 rockers, CAI, Titan 18's, Cranked and 2in block, Custom Pioneer Touchscreen, 2 12" Pioneer Subs
