Results 1 to 4 of 4
1996 vortec 350 timing???
This is a discussion on 1996 vortec 350 timing??? within the Technical / Maintenance forums, part of the General Discussion category; Hey guys, does anyone know what base timing, and total timing a vortec 350 is programed to run at? I ...
    Apr 2010
    Wisconsin
    Hey guys, does anyone know what base timing, and total timing a vortec 350 is programed to run at? I know about the GM tech tool to set timing, I am just curious if anyone has a spec for this?
    Apr 2010
    Wisconsin
    Re: 1996 vortec 350 timing???
    Bump....is there a better forum for this question or someone I could as for by name??
    0_o o_0 0_o o_0 98GreenMachine's Avatar
    Aug 2005
    St. Paul, MN
    Are you trying to set the timing or just want to know what the PCM timing tables are?
    98 K1500 Z71 - 204k | L31 | 60E | 3.73's | 3" BL | 33x12.5x15 Dick Cepek F-C II's | Dynomax Ultra Flo X DI/DO | 14 MPG
    Apr 2010
    Wisconsin
    Wanted to know about the timing tables. Base timing and full advance. I know the computer varies it depending on the input from various sensors (ie map, knock, ect....). Just trying to see if of will be close with the way I want to modify my engine. Thanks guys!!
