Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Larger PF48 - PF63, Finally.
This is a discussion on Larger PF48 - PF63, Finally. within the Technical / Maintenance forums, part of the General Discussion category; I think bypass would be a legitimate factor, under load. As the media becomes more restrictive more oil is going ...
  1. #21
    Nov 2005
    Lanark, Ontario
    Re: Larger PF48 - PF63, Finally.
    I think bypass would be a legitimate factor, under load. As the media becomes more restrictive more oil is going to have to bypass media to meet flow demands. My understanding is a fresh filter is nearing it's max delivery before using bypass under full oil demand.
    I still see no reason not to run the bigger filter. The WIX brand costs the same for the PF48 or PF63 equivalents. Plus I'll actually be able to change it by hand.
    GM powertrain warranty was good to me; both wheel bearings, valve cover, axle seal, u-joint, exhaust manifold bolts (heads fell off). All that with no service records (I'm the second owner).
  2. #22
    Registered User daved931's Avatar
    Apr 2008
    Bangor, ME
    I'm probably going to try this at my next oil change. I'll go for the Wix version at Napa.
    1999 2 Door Tahoe 4x4 w/ 14 Bolt SF & TruTrac. All kinds of upgrades, SOLD 1/2012
    2008 Silverado 1500 Z71, leveling kit, exhaust, SOLD 9/2014
    2014 Silverado 1500 Z71, stock for now
  3. #23
    It's What Lurks Within...
    May 2002
    Edmonton Alberta
    At extended WOT I would imagine the oil pukes through the bypass but I am willing to be no matter how big a filter it would anyhow, lol. Mind you don't see any reason a larger filter would be detrimental at all either. That said I just don't think it's absolutely required by any stretch either. If I find an Amsoil version of it I might go that route too honestly. This is my first go of Amsoil in a personal vehicle so we shall see how it does according to the lab.
    JUST FOR CLARIFICATION
    I hate GMT900 trucks period.
  4. #24
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by Badass69 View Post
    BITOG had a cross ref IIRC for an amsoil version of the PF63.
    I'm just looking forward to not having to clean off a filter wrench (will actually be able to get my hand on the longer filter) after the ADBV pukes out that last 1/2qt.
  5. #25
    NO ROOF RACK NEEDED kemble's Avatar
    Aug 2008
    KENTUCKY
    I would like a longer filter just to ease the install/removal procedures.
    SOLD: 04 z71, 3200 circle D, longtubes, Corsa sport, TBG 4l60e, 93 BB tune, 4500K HIDS, and other aftermarket stuff.
    Quote Originally Posted by 03SMURF View Post
    you have the meanest sounding 5.3 I have ever heard in person
  6. #26
    May 2002
    Edmonton Alberta
    Since I despise that BITOG site I just looked it up. Amsoil's version of the PF63 is indeed available under the number EAO18not that I need one, lol. I keep forgetting the title and the fact the filters changed in 2007..... Duh. The longer version for my truck is same as the PF61, because I have an 05, not that it matters here.
  7. #27
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by kemble View Post
    Longer PF46 equivalents have been around for a while.
  8. #28
    Nov 2005
    Lanark, Ontario
    Finally needed an oil change. WIX 57045 (PF63 equivalent) went on, looks like it actually belongs there compared to the stubby little PF48.
  9. #29
    Nov 2005
    Lanark, Ontario
    2000mi, no complaints.
    Another 3000+ to go before it comes off.
  10. #30
    Registered User Blue 04 Z71's Avatar
    Sep 2007
    Reading, PA
    Hmm whats the larger filter that replaces the pf46 for my 04?
    EDIT found it wix # 51522. Can get a case of 12 for 60 bucks. Might buy them seems like a good deal 5 bucks a filter. Delcos are over that at AAP or AZ
    04 1500 Z71 6.0 LQ4 swap, BlackBear 06+ Grill/Hood, Vette servo, 3 BL,RC Keys, Truxedo, Bull Bar,KC, Cooper ST's Bilstein 5100's Tow's, Pypes M-80.
    1989 Silverado 2500 94+grill, Ram air hood, Mild built 355, Th400,
  11. #31
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by Blue 04 Z71 View Post
    Hows that 6.0 treating you? Nothing short of fawking awesome I imagine.
  12. #32
    Sep 2007
    Reading, PA
    Quote Originally Posted by Quyonmob View Post
    O yes the 6.0 is the $hit. In the future the OBS is getting an ls swap and Im not even bothering with a 5.3 going straight to 6.0. This motor feels alot more powerful.
  13. #33
    Registered User Blackhawk7's Avatar
    Mar 2012
    Arizona
    Sorry to ressurect an old thread, but did anyone ever try actually putting the PF63 instead of the PF48?
  14. #34
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by Blackhawk7 View Post
    If you are going to dig it, you should try at least reading it.
    I'm at about 4500mi on the WIX 57045 (PF63 equivalent). I have no reason not to spin on another once I hit my OIC... sometime between 5500 and 7500mi.
  15. #35
    Mar 2012
    Arizona
    I saw you were using the WIX, I meant the actual ACDelco lol
  16. #36
    Nov 2005
    Lanark, Ontario
    Why? I think you missed the point.
    The PF63 is the same construction/quality of the PF48, which is not the point of the thread.
    The point was the significant size difference between the PF63 and PF48, which the WIX equivalent, the 57045, is relevant.
