Results 1 to 8 of 8
Hey guys! 5.7l Vortec plugs & Compression help needed
This is a discussion on Hey guys! 5.7l Vortec plugs & Compression help needed within the Technical / Maintenance forums, part of the General Discussion category; Hey everybody! I found this forum searching for info on my '97 Cheyenne 2500 8600lbs GVWR 2wd that I just ...
    May 2012
    Atlanta, GA
    Hey everybody! I found this forum searching for info on my '97 Cheyenne 2500 8600lbs GVWR 2wd that I just picked up the other day. Performancetrucks.net seems useless for anything thats not LS related, hopefully you guys can help.
    Chassis has ~350k on it, unknown on engine. I just did a compression test and got the following results:
    1 - 170
    2 - 195
    3 - 181
    4 - 185
    5 - 169
    6 - 184
    7 - 195
    8 - 210
    Numbers seem a little off, but not horrible if the motor really does have higher mileage. However, spec I found in Alldata was only 100PSI, which did seem suspect. Are these compression numbers normal, and what is the actual spec? Also, the plus look HORRIBLE. Most look rather white like the trucks been a wee bit lean, but 1 plug, #6 I think, looked particularly bad. Can anybody identify whats on this plug? Is it coolant, carbon, what?
    May 2012
    Atlanta, GA
    Re: Hey guys! 5.7l Vortec plugs & Compression help needed
    Well damn, looks like I can't post the pictures until I have 5 posts..... BRB!
    May 2012
    Atlanta, GA
    May 2011
    Arizona
    A few specs from a factory 1998 manual for the 5.7 Vortec:
    Disconnect power to the ignition coil
    Disconnect Injector harness
    Remove all spark plugs
    Block throttle wide open
    With gauge installed, crank engine through 4 compression cycles
    Repeat on all cylinders
    The manual doesn't give an exact compression spec, but states:
    No cylinder shall be below 100 PSI
    No cylinder shall be below 70% of the highest-reading cylinder
    All of your readings are well above 100PSI
    70% of 210 is 147. Your lowest is 169, meaning that it is well within specs.
    Depending on mileage, your plugs don't look that bad to me. The white, fluffy accumulation is mostly caused by fuel additives that the refiners add.
    If it were me, lacking any driveability complaints, I'd put in a new set of Delco plugs and retest it (see above) after 10 or 20 thousand miles.
    Nov 2005
    Lanark, Ontario
    Plug deposits look like ash, likely a little blow-by.
    How long were those plugs run?
    May 2012
    Atlanta, GA
    Quote Originally Posted by Quyonmob View Post
    No idea, I just bought the truck. They don't look THAT old though. I'll do a wet compression test this weekend and a leakdown and see what we get.
    Registered User Chevy53's Avatar
    Mar 2012
    Boston MA
    i suspect your going to have better numbers with wet tests your dry tests are fine doubt a wet is even needed deffinitly good numbers for a unknown miles engine
    current mods -
    Cree reverse light bulbs
    Candied tails
    Blackbear Tune
    Future
    May 2012
    Atlanta, GA
    Quote Originally Posted by Chevy53 View Post
    These are good numbers??? . Seems I haven't spent enough time in Chevy land for this much variance (greater than 10%, let alone greater than 5% variation cylinder to cylinder) to be considered 'good' numbers. I'm wondering if I should just drop new plugs in it and Seafoam the hell out of it. I have a feeling it probably has a ton of carbon in it. Wish I could see inside those cylinders. Wonder if I can borrow my friends borescope..... :/
