Results 1 to 18 of 18
95 Silverado idles fine, dies when you put it in gear
This is a discussion on 95 Silverado idles fine, dies when you put it in gear within the Technical / Maintenance forums, part of the General Discussion category; Could I get some help guys? I have a 95 Silverado K2500 with a 350, automatic. Theres 174,000 miles on ...
    Registered User 400exHauler's Avatar
    Jul 2010
    Iowa
    Could I get some help guys? I have a 95 Silverado K2500 with a 350, automatic. Theres 174,000 miles on the truck but only 15,000 or so on a crate motor according to the guy I bought it from last fall. The truck runs fine, idles fine, but when I put it in gear, it dies or almost dies. It seems to do it more in reverse than drive, but maybe that's my imagination. I just replaced the fuel filter and cap and rotor, and I don't really think I gained anything, it still does it. The old cap and rotor looked pretty crappy though. Anyway, I can't help but think its a sensor but I have no codes and the check engine light isnt on. I've done a search on here but haven't found the exact same problem. Thanks for any help you can provide.
    98 K3500 Crew Cab, 454
    Jan 2012
    St. Louis
    Re: 95 Silverado idles fine, dies when you put it in gear
    Does it shimmy when it dies? Can you get it rolling at all? Could be your torque converter?
    Registered User robotic_junky's Avatar
    Mar 2007
    Indiana
    Check the wiring for the MAP sensor. I had the same problem on a 95 C2500 and one of the wires going from the MAP senor to the computer was bad.
    Here's a how to video.
    2005 Chevy Corvette LS2 DD 105k
    1991 Firebird n/a 190k
    1987 Silverado 350 HSR 230k
    1980 Bonneville 350 Olds. diesel 198k
    1993 G20 350TBI 252k
    Jul 2010
    Iowa
    Vikestand: No it doesnt shimmy, just dies...Robotic Junky: Thanks, I will check that. Anyone else have any ideas if it isnt something to do with the MAP sensor? Thanks everyone
    Mar 2007
    Indiana
    It wouldn't hurt to check your fuel pressure, but doubt that's the problem.
    Mar 2007
    MI/AZ
    Put the transfercase in neutral and try it if it does not stall its the torque converter.
    Habitual Troublemaker cancritter's Avatar
    May 2006
    Alberta Canada
    shifter linkage conection in engine bay slip or lose?
    [Stole/FOUND 13/03/08 :O)
    91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 blt,Hooker LT,areofilter,Extreme TBI.MSD.AGR still adding
    70 fury 3
    71 sport fury GT
    Jul 2010
    Iowa
    Ok thanks guys, hope to check these out this weekend.
    May 2012
    Cabot, AR
    i would check for a vaccume leak. You might also just unhook the battery and leat the computer reset. I had a similar problem on my wifes trailblazer and the battery thing did the trick!
    Jul 2010
    Iowa
    Ok, whats the best or easiest way to check for vacuum leaks?
    May 2012
    Cabot, AR
    You should only have a few vacuum lines. Check those first. Also, when is the last time you cleaned the throttle body?
    whats "smooth idle"? 11sectreefitty's Avatar
    Jul 2010
    Colfax, Louisiana
    i actually have a similar problem with my 94. Idles fine but when you put it into gear (m/t) and start goin down the road, at any speed, it wants to spit and sputter hear and there. You have to downshift, get the engine moving fast then shift back into the higher gear. I checked the codes and i got a 33 and 42. Low vacuum and Ignition control circuit error. About a week ago i had timed it and forgot to reset the ecm so i imagine thats where the 33 was coming from since the timing was off, the vacuum was screwed up. for a week its been missing while driving. pulled codes today and got 33 and 42. reset the ecm, and replaced the module and they both went away but it still misses while being drove. Not trying to thread jack but it seems like we have similar problems. LMK what you find out.
    90 C1500 rclb TBI 350/700R4/4.11's, B&M shift kit, 1 piece alum. driveshaft, JL xovers, pioneer 6's. HCCA 10", 1600w DHD monoblock-TOTALLED 8/9/09
    94 C2500 rclb TBI 350/NV4500/3.73's G80
    85 C10 rclb 305/700R4, H.O. heads, edelbrock highrise, performer 650 carb, MSD HEI, Hooker LT Headers
    Mar 2007
    Indiana
    Quote Originally Posted by 400exHauler View Post
    Most people spray carb cleaner around vacuum lines and gaskets (like intake manifold and throttle body). If you have a leak of either, the rpms for the motor will go up.
    Apr 2011
    Anna OH
    Most times that you have a vacuum leak on those its at the throttle body gasket. At least thats been my experience.
    Jul 2010
    Iowa
    Ok great, thanks. I also forgot to say that it doesn't do it everytime, but at least half the time. And if you two-foot it, you can prevent it from dying.
    GMC RULZZ NEUMANNZZ's Avatar
    Mar 2005
    San Diego
    I would check compression, fuel pressure, vacuum. replace cap and rotor.
    Matching Ninja 500r
  17. #17
    Jul 2010
    Iowa
    I have already replaced the cap and rotor, as well as the fuel filter. I didn't find any vacuum leaks with the carb cleaner trick. Every time I try to get it to act up so I can try the neutral transfer case thing, it won't act up! I'm gonna get a vacuum pump and try the map sensor test.
  18. #18
    plays w/hoses for a livin 454Cowgirl's Avatar
    Feb 2011
    Michigan
    I agree on the check compression and the MAP sensor.
    I had a 454 that was having this problem and it got progessively worse(acted like the throttle was getting flooded under a load like reverse or at a stop), even though it wasnt the torque converter it had been changed with a up graded 4L80E. After changing the timing chain, mutliple map, sensors, cap, rotor, wires, spark plugs, fuel pressure, nodes. All wiring checked out. All cylinders were running, but I can only assume it was a compression problem.
    92 Bamablue C3500 CCLB-12V Cummins Swap-Thread HERE
    93 Blk GMC ECSB 1500-305-312,000
    93 Blk GMC RCLB 1500-32V Northstar/4L80E-Escalade clip &wheels-Pics
    Totaled
    98 Arabian gelding & 08 Arabian Gelding-Original 4x4 vehicles
