I take them out through the wheel well
This is a discussion on a/c compressor within the Technical / Maintenance forums, part of the General Discussion category; I got 2000 gmc sierra 5.3 nbs need to change the a/c compressor. what is the easiest way? take out ...
need to change the a/c compressor. what is the easiest way? take out the bolts and remove from the top of the engine?
Other then the coolant lines and air intake do i need to take anything else out like the radiator?
thanks
2000 Silverado 6.0 4L80E 2wd
how do you tell which compressor you have without taking it out first?
I thought there was only 1 kind of compressor for these trucks? But I also take them out though the wheel well. Just remove the plastic liner and that's it, no need to remove the radiator or anything else.
2003 ECSB Silverado 2500HD 6.0/ 4L80e
1985 RCSB C10 TBI 350/ 700r4
1991 & 1990 Harley FLHTCU twins..
i was reading somthing ealier about it accually taking pag 46 oil anyone know about that?
