Results 1 to 2 of 2
SM465 Hydro clutch problems.
This is a discussion on SM465 Hydro clutch problems. within the Technical / Maintenance forums, part of the General Discussion category; on my 89 k5, having issues with the Hydraulic clutch system. Some times it works as it should. but every ...
    They call me......Scuba Underpowered's Avatar
    Jan 2005
    northern KY
    Some times it works as it should. but every once in a while the clutch wants to release with the pedal only about 1" off the floor. and not just a little grab, it goes from disengaged to darn near full engagement with just the slightest pedal movement. if i put it back on the floor it still stays partially engaged. I have to fully release the pedal, than push it through its full stroke to disengage the clutch again.
    bad master cylinder? they guy i purchased it from in February said the entire clutch system was brand new as of Dec 2011. clutch, slave and master alll brand new. that is just what he said. i Know the clutch itself is nowhere near brand new, but the slave and master don't look too old.
    master cylinder or could there be a larger issue?
    new tow Rig rattles and smokes
    '89 K5 trail rig
    Registered User 454cid's Avatar
    Mar 2003
    West Michigan
    Re: SM465 Hydro clutch problems.
    Yeah, I'd say a bad master, or maybe a slave. When I had a Toyota, I put a rebuild kit into the master, and it only lasted a short time...... maybe that's what he did.
    454cid
    1999 K3500 RCLB
