Results 1 to 2 of 2
'94 1500 4x4 no heat
This is a discussion on '94 1500 4x4 no heat within the Technical / Maintenance forums, part of the General Discussion category; Blower motor is new,heater core is new,coolant full,no blown fuses,blower works on all speeds,cool air coming from vents and defrost. ...
    May 2012
    Ionia(I-OWN-YA),MI
    Blower motor is new,heater core is new,coolant full,no blown fuses,blower works on all speeds,cool air coming from vents and defrost. Funky HVAC display. Can adjust from cold to hot w key on,but display is blank w truck running and when I push the +/- to adjust heat, the display flashes. I have the clicking from the AC vent motor that I need to fix. Not blowing any warm air at all. I'm really confused. Any ideas?
    Registered User Srabai47's Avatar
    Dec 2010
    Toledo
    Re: '94 1500 4x4 no heat
    sounds like its busted. if you pop the tape player out/whatever you have in the center of the dash you can look in there and see a cable that connects to a red clip. that cable is what controls the heat/coolant going into the heater core.
    1994 Chevrolet C1500 Suburban 5.7 260,xxx miles.
    1994 Chevrolet C1500 SCLB W/T 4.3 TBI NV3500-(Rebuilt 02/23/12) 3.42 --268,xxx miles -Blew motor (3/20/13)
    1992 Toyota Celica (182,000miles) - Sold
