Results 1 to 15 of 15
4l65 trans issues....help!!!!!!
This is a discussion on 4l65 trans issues....help!!!!!! within the Technical / Maintenance forums, part of the General Discussion category; ok to start off with, I took my truck to a few tranny shops a few months ago and and ...
    May 2009
    surprise, az
    ok to start off with, I took my truck to a few tranny shops a few months ago and and most said my 2-4 band was going out cause 1-2 shift wasn't hard anymore. another said I had low trans pressure so I tried turning the pressure up on the selenoid and that didn't help. well I pulled my truck out of storage again today and cleaned the engine bay and went to drive it around the block and I have to shift it manually and I only have 1st and 2nd, no 3rd or4th. but when I shift manually from 1st to 2nd it hits hard like it use to. what could this be? bad computer? wiring, selenoid? this trans is starting to piis me off. when I narrow down one problem, that problem acts normal and another shows up. any ideas?
    info on trans. 4l60 with 5 pinion planetaries, 9 pack 3-4 clutches, corvette servo, and stock verter.
    94 gmc sierra xcss 4" lift on 33's. forged 383 stroker, pacesetter LT's true duals with x-pipe and dual 40 series, built 4l65e, 14 bolt SF conversion, and 6 lug conversion.
    GMC RULZZ NEUMANNZZ's Avatar
    Mar 2005
    San Diego
    Re: 4l65 trans issues....help!!!!!!
    usually no 3rd or 4th gear means no 3-4 clutches. is there a lot of debris in the pan?
    Matching Ninja 500r
    May 2009
    surprise, az
    Quote Originally Posted by NEUMANNZZ View Post
    no the fluid is dirty, but when I parked it 3-4 gears were working just fine. this is the first time its moved since then and I have to shift manually to get 2nd gear. trying to go into third it just wont even shift. I think the computer might be the issue, not 100% on that tho. the 3-4 clutches are the 9 pack raybestous. I've never had an issue with slipping or anything. I still have some time to go pick up a computer and try that, maybe my custom chip got shorted out.
    Mar 2005
    San Diego
    go here for troubleshooting:
    http://www.atraonline.com/manuals/ge.../tetdv-c3b.htm
    http://www.atraonline.com/manuals/ge.../tetdv-c3e.htm
    using the above guide check for 12vdc going to the transmission if not check fuzes and wiring.
    Matching Ninja 500r
    May 2009
    surprise, az
    thanks for these. I'm gonna check that next, once the engine cools down. how would I check to see if the computer is functioning correctly?
    May 2009
    surprise, az
    ok I just found out even tho the CEL didn't come on it still has codes there. and here they are.
    59
    Transmission Temperature Circuit Problem (DFI)
    Transmission Temperature Circuit Low (4L60E, 4L80E)
    67
    Cruise Control — Switch Shorted During Enable
    Torque Converter Clutch Solenoid Fault (4L60E)
    82
    Shift Solenoid A Circuit Error (4L60E, 4L80E)
    ok some more help please. I'm thinking the computer is freaking out.
    5TOCK silverado_lover's Avatar
    May 2009
    Galveston, Texas
    I had the same prob once upon a time and it was the PCM not commanding the trans to shift
    '95 C1500, LT's, 3200 stall, and some PCM tweaking
    Quote Originally Posted by Chevy4life11 View Post
    ive got 8 inches and i still wish i had 6 more
    May 2009
    surprise, az
    Quote Originally Posted by silverado_lover View Post
    thats just what I wanted to hear, thank you. now I am 98% sure of the problem.lol also some time in the near future I'm gonna be bugging you about how to do a ls swap in my truck. thats if I can't get better fuel economy out of my race engine I built.lol
    Mar 2005
    San Diego
    ensure the problem isnt in the transmission or wiring to transmission before replacing the computer.
    Matching Ninja 500r
    May 2009
    surprise, az
    I just replaced the computer so now I know it has to be in the trans. it still has the same issue. the only thing I did to the truck before it sat was adjust the pressure solenoid up a bit, could that cause the shift solenoids not to work? could the trans have too much pressure and create error codes?
    Mar 2005
    San Diego
    its possible or could be the wiring in between. should of used a line pressure guage to confirm line pressure was in spec. now your gonna have to check the wiring and selenoids. was the wire harness replaced in the transmission?
    Matching Ninja 500r
    May 2009
    surprise, az
    I believe so, but that was 2 years ago. its just wierd, work when I parked it, now it wont. someone said it might be in limp mode since I get 1st and 2nd and for 3rd it just revs. I sure hope I don't need a rebuild.
    Mar 2005
    San Diego
    might be in limp. trans fuze good?
    Matching Ninja 500r
    May 2009
    surprise, az
    thanks NEUMANNZZ I found the problem it was the TPS not working right. but it never threw a light so it was a shot in the dark and I was shaking my head cause I'm an idiot for not checking it first. the trans still doesn't shift hard into 2nd like it should so here in a few weeks I'm gonna change the pressur solenoid and flush the trans with a new filter too. that should fix that problem I hope.lol
    Feb 2012
    Texas
    when my '97 was taking off in 2nd and had no converter lockup it ended up being the 1-2 gear solenoid blowing up, one of my trans cooler lines was kinked and I guess that caused the solenoid to blow up.
