make sure the pads slide good you may have to replace the hardware for the calipers and grease them up
This is a discussion on 2011 2500 Rear Brakes within the Technical / Maintenance forums, part of the General Discussion category; Hey Guys one of my work trucks keeps warping the rear rotors. We pull a lot of heavy trailers with ...
Hey Guys one of my work trucks keeps warping the rear rotors. We pull a lot of heavy trailers with it but all the other Chevy 2500 we have don't have the same problem. I dont Know if its because they are 4 door long beds and this one is a regular cab short bed or what. Cant figure it out please help.![]()
99 GMC Yukon SLE 4dr
KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
87 Firebird, 07 Monte Carlo lt, 98 Bonneville SSE, 04 F550 CC 4wd service body
Check calipers and slides seems like calipers are sticking up and holding on
-Ziggy-
current mods -
Cree reverse light bulbs
Candied tails
Blackbear Tune
Future
Yall think the piston is releasing ans staging on the rotors
Sent from my HTC Sensation 4G using Tapatalk 2
a number of things can warp rotors and without knowing what you have or havent done its hard to say
Take them apart.
Make sure the e-brake is not partially enguaged.
Clean the caliper bolts and grease them with only brake grease. Other products will swell the bushings and cause them to stick.
Then take off the caliper brackets. Take the stainless steel clips off, clean under them, put a small amount of brake grease under the clips.
Put your pads on the caliper bracket and make sure they slide. If not file the ears of the pad down until they slide. Just enough to get them to slide.
Then put the bracket and caliper on, make sure the caliper slides. Then put the pads on.
05 Cavalier
Hey guys thanks for the responses. We ended buying new calipers.
Yeah its one if our work trucks
under warranty take it in.
Matching Ninja 500r
Nope sorry long bed
