Results 1 to 2 of 2
Brake light doesn't work with night running lights on
This is a discussion on Brake light doesn't work with night running lights on within the Technical / Maintenance forums, part of the General Discussion category; Hey All, I'm having this really weird issue with the left tail light on my '98 C1500 Truck. When the ...
    Jun 2012
    A, A
    Question Brake light doesn't work with night running lights on
    Hey All,
    I'm having this really weird issue with the left tail light on my '98 C1500 Truck. When the night running lights are switched on, the left brake light and turn signal does not work, but the night running light does work. When the night running lights are switched off the tail lights work normally (brake light, turn signal). The right tail light functions normally in all states.
    I have already replaced:
    1. Bulbs
    2. Tail Light Circuit Board
    3. Tail Light Connector Harness
    I have also checked the fuses and those are all normal.
    Any thoughts? I'm at a loss. Thanks in advance for the help.
    Registered User ToyHauler's Avatar
    Jun 2006
    Western NY state
    Re: Brake light doesn't work with night running lights on
    try adding extra ground jumper see if that changes it. is this the original problem or did it happen when you changed the housing
    99 GMC Yukon SLE 4dr
    KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
    87 Firebird, 07 Monte Carlo lt, 98 Bonneville SSE, 04 F550 CC 4wd service body
