any fluid in the front diff?
This is a discussion on Harmony/humm coming from front end. within the Technical / Maintenance forums, part of the General Discussion category; Not a full size but part of my fleet 2000 GMC Jimmy, 122,000kms. The front end makes alot of noise ...
The front end makes alot of noise which isnt dependent on throttle. It gets into a harmony which changes with speed and is also felt in the floor boards and steering wheel. I have narrowed it down to the front end by unknowingly having different air pressures in both front tires (10psi difference) this changes the frequency of the harmony and when I evened out the pressures the harmany went back to "normal". I am assuming this is a differential issue due to the noise changing when the spider gears RPM changes.
Background story: We drove the vehicle for unknown KM's (less than 100) with it in 4wd on dry pavement, I accidently hit the switch and never noticed. Thsi was last September. I am thinking this was the start of the issue.
Anyone ever expereince this? I have a feeling a bearing is finally letting loose or a gear is worn.
I have checked:
Wheel bearings: 1 replaced other is tight
CV shafts: Nothing unusual
Stub Shafts: minimal movement at the diff.
any ideas?
Thanks, Alex
'96 Chevy K1500HD ECLB, 385,000km and still goin strong...ish, Rebuilt 355 w/4L60e on its last legs
'07 Pontiac G5, Wifes Blurple commuter, 97,000km
78/80/93 GMC in many pieces and places waiting for time and effort.
Matching Ninja 500r
Yes, and I am trying 30% lucas in it to see if it changes the noise. I have changed the fluid and no large metal particles but is metalicy.
If it looked like metal flake paint you have one or a couple of bearings on their way out.
