Results 1 to 7 of 7
97 1ton power steering issue
This is a discussion on 97 1ton power steering issue within the Technical / Maintenance forums, part of the General Discussion category; I have a 97 Chevy 1 ton and I'm having trouble finding a power steering pump for it. I guess ...
    Nov 2012
    The Woodlands
    I have a 97 Chevy 1 ton and I'm having trouble finding a power steering pump for it. I guess due to the pump having and EVO filtration system on it. Truck has a hydo boost and this is the only truck I've ever owne that has this style pump system on it. My question is, does anyone know where to purchase one. It is actually leaking where the pump mates in to housing. Wasting more money on fluid then gas. I've tried all auto stores as well as the dealer. I figure I have to remove and have sent out to get rebuilt. Can anyone help with this??
    Registered User bowtie44s's Avatar
    Aug 2011
    WV
    Re: 97 1ton power steering issue
    lmctruck has them, their site isn't working right now so I can't send a link but it's page 114. $100 which is a lot cheaper than the regular pump.
    Jeff
    '88 Chevy K3500, aluminum head roller cam 511in³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
    Oct 2007
    TN
    You can put the pump on from a 96 without the evo.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Registered User Haulin_Dutch's Avatar
    Nov 2012
    PA
    RockAuto has them for about $85.00 plus core, ...the EVO sensor is a seperate purchase, does not come with ANY pump. make sure you replace the 3 orings on the EVO.
    Nov 2012
    The Woodlands
    sorry I have not responded in some time, I got a job that allows me to drive someone else truck and my baby sites back in Texas. Sad to say I still have not replaced the pump on it. im out f town 10 weeks at a time, so she sites. Ill get it fixed and inform you of how I went about it. Also due to truck being 1 ton with a hydro boost, the standard pump will not work. I need the evo for line pressure. well, that's what ive been told.
    Oct 2013
    Lockhart, TX
    I was just looking at pumps today and Advance auto had them for 135. You can get a 40 off coupon and shipping is free. I was just looking because I have hydro boost and mine is on the noisy side. I am going to flush it good first.
    Oct 2007
    TN
    The pump off of a 96 will work fine, you just won't have the evo anymore.
    In 97 they added this to the steering system. At low speed it lets more pressure out so it's easier to turn.
    At high speed it backs the pressure down so you don't wander all over.
    Without it will steer just like a 96. Will be a stiffer steering wheel but that's it.
    05 Cavalier
