Results 1 to 9 of 9
2000 Chevy Silverado Manual Transmission Fluid Capacity
This is a discussion on 2000 Chevy Silverado Manual Transmission Fluid Capacity within the Technical / Maintenance forums, part of the General Discussion category; Sup, I have a 2000 Chevy Silverado with the 4.3 V6 and manual transmission. I am planning on changing my ...
    Registered User _HeavyChevy's Avatar
    Nov 2013
    FLA
    Sup, I have a 2000 Chevy Silverado with the 4.3 V6 and manual transmission. I am planning on changing my transmission fluid tomorrow but having difficulty finding how much exactly it takes to fill it after it has been drained. Does anybody know? I have read on one post somebody said 2.0 quarts and then somebody else said 3.0 quarts??
    Nov 2013
    FLA
    Re: 2000 Chevy Silverado Manual Transmission Fluid Capacity
    Also does anyone know the rear differential fluid capacity? What weight and brand to use?
    Registered User bulletpruf's Avatar
    Jul 2013
    Naples, Italy
    Quote Originally Posted by _HeavyChevy View Post
    I'm using Valvoline synthetic 75/90 in my 99.
    Nov 2013
    FLA
    Quote Originally Posted by bulletpruf View Post
    Cool, Thanks. Do you know how much it takes?
    Registered User Chriscon7's Avatar
    Jun 2011
    Colorado
    You just fill it up until it reaches the fill plug. Buy a few bottles and return what you don't use
    06-2wd-4.8-5speed-LR4-Z85-40series-Baja 8s-TrueTrac-4.30gears-J&S Performance Tune
    Quote Originally Posted by kyviabama View Post
    Every guy thinks he has an additional 2".
    Nov 2013
    FLA
    I just overfilled it then I lowered it to the ground and let the excess spill out. Took about 2-3 quarts.
    Nov 2013
    FLA
    For the transmission. For the rear differential is the same? Just fill it till its full?
    Registered User PinkFloydChevy's Avatar
    Mar 2012
    on his crimson ship
    Yea. Or look in the owners manual for the capacity, or search online.
    Dec 2011
    Lake City, MN
    The NV3500 5 speed trans (has all aluminum case) takes 2.2 quarts of Synchromesh trans fluid and the rear diff takes 2.1 quarts of 75W90 synthetic gear oil. Fill the trans level with the bottom of the fill hole but only fill the rear diff until the fluid level is about 15mm below the fill hole per the GM service manual.
